Question about Bell & Howell B we Bell & Howell Spectrum XF 8120D
When Scanning a document ,peripheral mechanical malfunction error 20093
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Getting p1504 error code for 2001 mustang V6 3.8, how do i fix
Your code designates an Intake Air Control circuit malfunction. Without proper scanning tools, you will probably have to take it to a qualified mechanic. Sorry I can't help you more, but without the car, that's all the info I can give you.
Sep 22, 2011 | 2001 Ford Mustang
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
An error ocurred communicating with the scanning
Hi I will be glad to assist you in this issue. here is the libk that will fix the issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897542&cc=us&lc=en&dlc=en&product=391153
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00040499&cc=us&lc=en&dlc=en&product=391153
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Oct 31, 2008 | Computers & Internet
Trouble scanning or faxing
yeppers..that's the mechanism under the glass..sounds like either it's stuck or the belt is going bad..service level issue, I'm afraid.
Aug 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printer malfunction
Some sort of mechanical problem ?
Google the newsgroups with your error number (pity you didn't post it here :-) )
Apr 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Colorful lines down the scanned pages...
This could be due to excessive usage which the scanner can not tolerate and as a result the movement of the scanning mechanism losses precision. So avoid continous scanning.
Feb 08, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Power On indicator Flashing, Scanner won't scan
It could be anything, when there's a hardware malfunction, the scanner just will not allow any action. As it is also an old scanner, any documentation of LED error codes will be long gone, too. It's a shame when well built peripherals die.
Sep 07, 2007 | AcerScan 620U Flatbed Scanner
Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
Bell & Howell B we Bell & Howell Spectrum XF 8120D Logo
573 people viewed this question
Top Bell & Howell Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
