I have had no problems at all untill now.. and its say error code 6000, there is no paper jammed in it
Try to use the reset solution from this website, How to reset canon mp460. It will do a factory reset on your canon printer. It did worked for me, not the same error though but have the issues with false paper jam.
I have same proble, at this time i can resolve this problem, but i guest it's adaptor have broken, coz it can move motor again, may be, but i dont have any batery to test this
Solutions for error 6000
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1.
Press ON/OFF switch to reset the multifunction device
2.
Removing paper jams MP450 / MP460
3.
The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
had a paper jam, found sheet soaked in black ink, cannot reset printer,
i turn on the printer i have no cd'rom for it i dont know where it is all the printer says is error code 6000
paper got jammed, pulled it out, now got error code 6000 and cant get rid of it. help
I now have the same problem. FIrst I had error code 5100 after I printed off a picture. Turned off printer, turned back on to find error 6000. THere are no paper jams.
I have Cannon MP600 printer with error code 6000 not responsive to any button control. Left unplugged for hours, same problem, no paper jam?
found pen in paper tray now trying to reset error code 6000
ERROR CODE 6000
