Question about Norcent Technologies LM450 (Silver) 14 in. Flat Panel LCD Monitor
Speakers don't work
My monitor speakers just stopped working. I know it's not the computer itself because I've checked to make sure all of the right devices are on and it's not on mute.
Pleas check the adapter
Posted on May 16, 2008
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
No Sound LGW234T-PF
The LG W2343T does not have speakers. So you can't plug in a 3.5 mm audio patch cable between the computer's line out or headphone jack and the monitor. (Similarly, other devices can't provide sound to the monitor.)
Are you using a desktop or a laptop? If you have a laptop, make sure that the correct audio drivers are loaded for your OS and make sure that the audio isn't muted (look in the lower right on a Windows system in the tray for the speaker icon). On an HP laptop, we had to use the Component Services (Control Panel > System and Security > Administrative tools > Component Services > Services in Windows 7) and stop all audio services and restart them. Then reboot the computer to use the internal speakers at a reasonable volume.
For any unit with external speakers (required for a desktop, optional for a laptop) , connect the speakers to the audio out port (green for 3.5 mm for single connection speakers, see the manual for other speakers) or the headset port. Next make sure that the device drivers are loaded and correct for your sound card (or motherboard audio). (Control Panel > Hardware and Sound > Device Manager). If your sound isn't active, look at the Sound header. Then choose Manage Audio Devices and the Playback tab to select the desired speaker option. (Again these are for Windows 7).
If you still have no audio, make sure that the speakers have power (USB cord or AC adapter plugged in depending on the speakers). If it is USB powered, try a different port or a powered hub. If you have an AC adapter, check if it is warm. Some speakers have power/volume knobs. So check if they are on (if there is an LED, that is an easy check). If still no audio, try a different audio patch cable, if possible. Otherwise, try different speakers. There may be a damaged wire preventing the speakers from working. Depending on the problem and if your speakers are under warranty, it may be worth fixing or not.
Documentation for the monitor is available here: http://www.lg.com/us/computer-products/monitors/LG-lcd-monitor-W2343T-PF.jsp . Click on the Support tab.
If you want to use a stereo receiver with RCA audio inputs, you'll need an adapter or a 3.5 mm to RCA m/m audio cable.
I hope this helps.
CIndy Wells
Oct 21, 2011 | LG W2343T-PF Monitor
We have older speakers that came with our computer, and we just moved and since we've moved no sound has come out of the speakers. i have checked a million times and everything's plugged in. i...
First check if the driver for your speakers is up to date. For all we know maibe something that was installed automaticaly or by some one might be interfearing with them. Go to the Window menu, click on Conrol Panel, click on speaker settings, and check to see if anything looks off (like everything is gray and you can't really select anything). If everything seems ok check all the volume settings. Remember there are 3 things that control the volume on the speakers. 1: the nob on the speakers; 2: the volume on your desktop (lower right side next to the clock); 3: the volume on the program you are using (like windows media player). Another thing to remember is some computers come with a mute button (ether on the keyboard or monitor. If your computer has a play/skip/stop buttons it most likely has a mute button. Oh, and some computers have a volume nob next to the CD/DVD player (where you put in disks). Maibe some one turned it down as they grabed to move it. Make sure it's also turned up. If they're all turned up then most likely something got bumped loose during the move. In wich case you'll have to open it up and check the conections. It'd be a good idea to test some one elses speakers so you'll know if it's the computer or the speakers...or you could try pluging in the speakers you have into something else (like an MP3 Player).
Sep 19, 2011 | HP JBL Platinum Computer Speakers
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I have lost my speakers on the monitor. Using Microsoft XP, they were working but now they are not. Did some driver updates then lost the sound on the monitor. Checking the control panel indicates that...
Sounds like you've lost audio output from the sound card. Unplug the audio cable from the sound card and plug in a set of ear buds or headphones. If you don't get any sound your driver's not working. Try reinstalling the old driver.
Aug 08, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
I cant get sound from my Logitech speaker system.I've checked everything.I don't know why it's not working,but in the control panel it says "There is no system on"
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 08, 2011 | Logitech S120 2 Speakers
My monitor speakers are not working name of my monitor is Spectrum 9 GIrsA or GlrsA could you help me locate the problem . I know tht the speakers work ,because when I hook up another cpu the speakers...
check if you have installed your sound drivers and the monitor drivers , if they working good on other cpu that should fix your problem. if you don´t know how to check or update drivers let me know. and good luck
Jun 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Monitor speakers stopped working
Make sure that the audio cable from the computer is in the correct audio output (small green socket) and connected into the monitor. You can test the monitor speakers with an MP3 player or a smartphone. Also check that the volume on the monitor is up.
Jan 28, 2018 | BenQ FP71G 17" LCD Monitor
Speakers
check in the monitor menu for a sound X fol around with that and make sure your green cable is connected from your computer to the monitor
May 03, 2008 | HP Pavilion F1703 17" LCD Monitor
Norcent Technologies LM450 (Silver) 14 in. Flat Panel LCD Monitor Logo
150 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
