Question about Konica Minolta Bizhub c203 Copier
How do i set my KonicaMinolta bizhub C203 to copy in black and white by default?
    New Friend:
  • Konica Minolta Expert
  • 118 Answers
Set the copier on black then go to utility/counter, user settings then set current settings
Posted on Oct 16, 2011
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
Jun 13, 2016 | Konica Minolta bizhub Office Equipment &...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
How to change to the default from colur to black and white on Bizhub series C35
Ok, it's been a while but here's what I remember. If your talking about default black and white COPYING, try the following. First set the machine to make B&W copies, then hit utility and go to user mode, touch current settings, then OK. B&W should now be the default.
Mar 14, 2011 | Minolta bizhub 350 Black and White Copier
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Mar 31, 2009 | Minolta Di3510f Bizhub Copier
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub c203 Copier Logo
365 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
