Question about La Cornue Grand Palais 180 Dual Fuel (Electric and Gas) Kitchen Range
I have la cornue chateau 147 that we came heir to on buying a house. There are two poblems - the electric oven does not work and the gas oven makes a VERY loud clanging soune when it heats up. Any ideas?
3 Suggested Answers
SOURCE: no operating instructions
the top one turns the broiler elements on 1 is for the center element 2 is for the 2 side elements and 3 is for all 3 elements. The next dial down turns the electric on or off . the third dial is the same as the top except for the bottom elements
Posted on Jan 31, 2010
SOURCE: Oven on European La Cornue chateau 120
it could be your air to gas mixture is too lean, and the flame is blowing out. the oven will then turn off, but it is producing a lot of carbon monoxide have to see flame to really tell.
Where is the safety trip on the electric oven?
Typically on the back of the oven there is an access panel at the top behind the control's should be a circuit board with a fuse ?
Feb 21, 2015 | La Cornue Chateau 120 Dual Fuel (Electric...
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
Gas ignition failure
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. -- defective thermostat
  2. -- defective selector switch
  3. -- defective gas safety valve
  4. -- defective gas valve coils
Dec 25, 2009 | La Cornue Kitchen Ranges
No operating instructions
Apr 11, 2009 | La Cornue Chateau 120 Dual Fuel (Electric...
Gerardo / Peru
Try Coast Appliance Parts (coastparts.com) and ask for Gabriel. He is very helpful.
Karl
Jan 05, 2009 | La Cornue Grand Maman Dual Fuel (Electric...
Nov 08, 2008 | La Cornue Chateau 120 Dual Fuel (Electric...
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
Open Questions:
La Cornue Grand Palais 180 Dual Fuel (Electric and Gas) Kitchen Range Logo
257 people viewed this question
Top La Cornue Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a La Cornue Kitchen Range Expert? Answer questions, earn points and help others
