Question about Epson WorkForce 600 All-In-One InkJet Printer
Paper jam back of epson 610 workforce all in one
TJ4722
  • 54 Answers
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Posted on Dec 13, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
Firetree
  • 179 Answers
SOURCE: My Epson 610 workforce says
Generally, regardless of the brand of printer, this sort of issue is caused when a paper jam was removed and one of the optical sensors inside the machine was damaged in the process. It will continue to show an error unless it is repaired or replaced.
Unless you have an Epson repair center close by (ie., don't have to ship it anywhere) you may be better off buying a new printer. The repair can be very time-consuming for anyone but an expert on that particular machine, and hence very expensive.
I know that's not good news, but hope it's helpful.
Posted on Jan 06, 2011
SOURCE: keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Posted on Jan 09, 2011
  • 794 Answers
SOURCE: my epson workforce 610 had paper jam and I had to
Hi gammon65026,
Have you already checked that there's no paper or any blockage left after the paper jam? If confirmed none then:
The repair can be very time-consuming and hence very expensive. you may be better off buying a new printer.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 25, 2011
Why is my printer in error state
Can you Clarify which type of error are you facing ?
Sep 21, 2014 | Epson Workforce 610 All In One Inkpr...
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson workforce 610 carriage flys to the right when turned on and say's paper jam. the only option is to shut off the printer
check if you open the printer door. there is a plastic strip with black lins on. clean it or check if it is in place.
Nov 07, 2011 | Epson WorkForce 600 All-In-One InkJet...
I keep getting a paper jam error and there is no paper in the printer. It prints one page and then gives me the error
usually there is some small piece of paper stuck somewhere, exploratory surgery with a LOT of LIGHT is the next step.
Jun 03, 2011 | Epson Workforce 610 All-In-One InkJet...
My Epson 610 workforce says it has a paper jam. But I have searched everywhere inside, even using a flashlight and twisting and turning the unit in every possible way. I don't see even the smallest shred...
Epson Workforce 615 problem started with a paper jam, got the paper out without any problem, then an error message to turn off the printer, which didn't work & when I did turn it back on there was a grinding sounds. I got the printer cartridge box moved over to the far right & there was a small white button that moved,so I used a Q-tip to hold it upright while turning on the printer. Woo Hoo, I'm back in business. Did have to clean the print heads.
Jan 06, 2011 | Office Equipment & Supplies
Keeps saying paper jamed when I try to print
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson WorkForce 600 All-In-One InkJet Printer Logo
803 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
