Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
My P5QC motherboard is possibly dead. PC crashed (after going to sleep when I left it playing BBC iplayer) overnight and I had to power it off and back on again. Now it will not POST or reach BIOS. No beeps at all, yet all fans are running. It powers on fine (can hear HDD whir and the motherboard LED is on green but after about 6/7 seconds, it shuts off. Then powers itself back on a couple of seconds later. From there it just runs the fans again with no beep. I'm hoping it's just my TX650w power supply that is faulty but the fan is running fine on that. Really hoping it's not my Q9300 processor or motherboard. Don't think it's my HD3870 GPU. Anyone have any suggestions? Thanks in advance.
  • 317 Answers
SOURCE: A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Posted on Nov 07, 2007
  • 86 Answers
SOURCE: Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Posted on Jan 27, 2008
  • 33 Answers
SOURCE: boot problems
This type of problem is so common nowadays. What I did is open up the casing, pulled out the RAM and by using pencil eraser, rubbed the contact pattern. Put it back and turn on your computer. Always work for me and hope it might work for you too.
Posted on Feb 09, 2008
SOURCE: pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Posted on Sep 12, 2008
  • 1027 Answers
SOURCE: motherboard cpu fan runs but no HDD led no POST beeps
Sounds like a cpu failure.
Posted on Apr 08, 2010
How do i use the bbc i player app installed on the tv
There are several different versions of BBC iPlayer which manufacturers use in their devices. Between these versions, due to technical limitations, there can be some variations in features (subtitles, HD etc.). Each device will need to be connected to the internet to use BBC iPlayer.
Without knowing the make and model this is the info available.
Dec 23, 2016 | Televison & Video
Tip
How to Crack/Wipe DRM from Downloaded BBC iPlayer Programs
Quoted from: iPlayer ripper
BBC iPlayer - A service that lets you catch up with radio and television programs from the past week of BBC. BBC iPlayer use Microsoft's "Play for Sure" DRM system as copyright protection, thus the programs are downloaded, they will self destruct after 30 days because it is 'DRM License protected'. And once played you have up to seven days to finish watching the program. BBC Content will be automatically deleted from your computer once its expiry date has been reached. If you are outside the UK and connected to the internet you can only listen live and listen again to most of our radio programs.
BBC iPlayer Ripper - Daniusoft DRM Converter makes it easy to remove DRM protection from downloaded BBC iPlayer programs, such as DRM protected WMV video files, to make these programs DRM free and non seven or thirty days time limited so that we can save BBC contents permanently, Or you can Rip BBC iPlayer programs to any portable devices like iPad, iPod, PSP, Zen, Walkman, etc? Or even can we burn the files downloaded from iPlayer to DVD disc.
In the following passage I am going to show you how to use Daniusoft DRM Converter to remove DRM protection from BBC iPlayer programs step by step.
Step 1: Free download Daniusoft DRM Converter. Install and launch it as what you usually do with other application software.
Step 2: Click the "Add" button to import downloaded BBC iPlayer programs files, or directly drag and drop them into the main window.
Step 3: Then click the low-right "Setting" button, on the setting board there are many options to costomize the output audio & video properties. Choose an ideal output file size and quality to meet your players' requirement.
Step 4: After finishing the settings, backward to main interface, click "Start" to begin the conversion process. When conversion done, you go with DRM-free BBC iPlayer programs in various formats, or enjoy BBC iPlayer video music on any portable devices like iPad, iPhone 4, iPod touch 4, PSP, Zen, Walkman, etc?
__________________________
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes
on Oct 18, 2010 | Computers & Internet
Netflix no picture
If you go to another streaming service, such as the BBC iPlayer, does that work?
www.bbc.co.uk/iplayer
Mar 02, 2014 | Computers & Internet
I cant't get bbc iplayer to play programmes: it comes up with: task queue failed at step 0: config empty. ITV player works perfectly but I prefer programmes from BBC. What can I do to solve this...
I am having the same problem,same error message. I only get the message when trying to view live TV using the iPlayer. The BBC News channel plays live OK through the BBC News website. Live sport broadcasts play OK though the BBC Sport website. I uninstalled Flash Player and then reinstalled. It made no difference. Please help.
Sep 11, 2011 | AnchorFree Expat Shield
Hi there, I have a samsung gt - s5620 monte, when I go onto BBC I player on the Internet browser the page comes up but the pictures and videos won't appear or play. It has worked before and this is a...
Hi there, I'm afraid i don't have a solution, but your not alone, my iplayer doesnt work either.... if i can get it running i;ll let you know! m
Jul 29, 2011 | Samsung S5620 Cell Phone
I want to play bbc iplayer downloads with windows media player si
I find the K-lite Codec pack covers just about every video format. The included older style windows media player classic is also far less problematic than windows media - download 'Full' version here;
http://www.free-codecs.com/download/K_lite_codec_pack.htm
Nov 03, 2009 | Compaq Computers & Internet
User guide for Acer laptop model 5535
Hi, I may have a possible fix for this....
I got an Acer Aspire 5535 for christmas off my parents and on christmas day had a problem where the screen randomly goes off into sleep and cannot wake up unless restarting. This is very annoying!!!
After narrowing the odds down, i found that after watching vidoes on websites such as Youtube or BBC iPlayer or even iTunes videos my computer went into sleep.
The only way to solve this... according to Acer - a new video chip needs to be installed so send it off to Acer.
After this it works fine as i found out after watching Top Gear and the new series of Reggie Perrin on the BBC iPlayer.
I hope this helps you - i know how annoying this can be.
Thanks =]
May 11, 2009 | Acer Computers & Internet
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
