Question about Garden
Need replacement drive belt for a powermatic #412 planer
  • tpryan575 Sep 15, 2010
    The drive belt broke and shredded - the markings on the belt say- BANDO135J HF. I cannot find a belt by this number anywhere. Was wondering if it is in the manual? I have a Powermatic 12 1/2 Planer Model #412 - circa 1989
  • 2,841 Answers
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
What belt(brand/numbers)to replace the one on a Powermatic Artisan 63A Table Saw?
Probably a long out of date question but my suggestion is to purchase a link style belt to replace the old hard drive belt that comes with the saw. It'll deliver more power to the blade, run quieter and work better. I also recommend replacing the drive pulleys while you're at it. Get a couple of balance ones.
You can get a link belt at Rockler or other woodworking outlets.
http://www.rockler.com/1-2-power-twist-plus-link-v-belt
Jun 19, 2014 | Powermatic Saws
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Have Powermatic Planer & can't get the infeed & outfeed rollers adjusted right. Takes all you have to operate it. 24" Planer less than 10 years old & probably doesn't have 200 hours total on...
The rollers may need to be reconditioned. Try cleaning with a solvent to soften them up. I hope this has been helpful please rate if this answer has been of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Powermatic 1791268 201HH 22" Planer w/...
I have a180 880--- planer and realised there are
A lot of equipment is built with sealed bearings these days--just a fact of life. Good luck!
Mar 23, 2010 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Trying to find a manual for a powermatic 18o planer. NOt having any luck. Thought there was a place on line to down load. HELP!!!
Try these folks. Ask for Rich Jenkins.
J Redmond Wm And Son Inc 320 Coweta Industrial Parkway, Suites A&B
Newnan, GA 30265
  • (770) 683-7297
Nov 19, 2009 | Powermatic Masonry Tools
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
