Question about Zanussi Washing Machines
My machine has a very slight leak could this be from the door seal ?
  • Zanussi Master
  • 17,129 Answers
The first hand inspection is the best opttion to finalise on the leak, If you move your palm on the area of the leak the water drip can be felt to confirm.
If it is the door gasket you can rotate the same to move it upwards to reduce the leak if from the bottom.
If not replace gasket.
Can als be due to drain hose /drain pump fault if dripping is at the bottom.
Posted on Sep 15, 2010
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Water leaks through wash powder draw and door itself
Water leak from drawer could be if the machine is leaning forward slightly and the leak from the door could be your door seal may need replacing.
Jan 20, 2010 | Hotpoint WMA58 Front Load Washer
Leaks from door seal
The best way to place a dishwasher in "unused" mode (when not being used, that is) is to park the door slightly open. This assures that the seal is not constantly crushed and takes a form that is too relaxed when it IS being used. . Unless there are extenuating siturations (like a rip in the seal, the machine filling too much, etc.), You might have to have the door seal replaced. You could try taking a very powerful hair dryer and heating the seal while you pull on it to make it take a better form with some spring, but often this doesn't help much. Give it a try, and park your door open a smidge when the machine is not being used. (Just have it unlached.) . Make sure your machine isn't filling too much. Sometimes the little float device (if equipped) is stuck. Reach down and diddle with this round float thing and make sure it is able to go up and down.
Nov 25, 2009 | GE Dishwashers
Water is leaking from the door. Do I need to replace the door gasket?
HI, first, make sure there isn't anything preventing the actual door seal from forming a complete seal around the door frame. this can be caused be a creased section of the seal, or a piece of debris. if the seal is free of the above stated issues, in should be replaced asap.
I would also inspect the door alignment as well. if the door is slightly mis-aligned, this will prevent the seal from making contact with the door frame in a appropriate manner, in return, causing a slight leak during the wash.
Sep 26, 2009 | LG WM-1832C Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Rubber door seal has disconnected
if the wire in the seal is propely positioned and not slightly askew it should work OK But if it looks correct and leaks you will need a njew seal as it may have been bent or stretched
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak water at the from door
HI. check to see if the front door seal is creased slightly. if so, try to straighten it so that it is flush with the door structure when closed. check the drum seal as well. replace the door seal if needed.
Over sudding can cause this as well. make sure you are using the correct amount of HE detergent.
Aug 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
AAA160 Washing Machine
yes most certainly, with leaks it is either the seals or cracks in hoses or rust holes in wash cylinder, but most likely the first too because of being a fairly new model
Jul 01, 2009 | Hoover AAA160 Front Load Washer
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
May 31, 2009 | Frigidaire Washing Machines
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
