posted by Smoochie on May 16, 2008
The Brothers 2820 tells me to change the drum. So I did with a new one and also the cartridge but the error message still pops up after every print job.
Comment by Smoochie, posted on May 29, 2008
Yes that did the trick. Thank you so much for your expertise.
Solution #1
posted on May 28, 2008
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
- Open the front cover.
- Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO". - Press 1 to reset the drum count.
- Close the front cover.
Comment by Avwrexit, posted on May 29, 2008
NE time dont forget to rate my response thanks!
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother IntelliFax-2820 Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Brother IntelliFax-2820 Plain Paper Laser Fax
Paper jam will not go
Paper jam will not go away Answer This...
Can I use the all in one phone...
I have a MFC-665CW, I am... Answer This...
INTELLIFAX 2820--PAPER/SCANNER...
thx for prompt reply... Answer This...
not connecting to fax out
The fax machine recieves faxes... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
