Master cooler A/C makes a terrible racket. Fanblades touches floor?
  • 455 Answers
Hello The fan blade has come loose.You need an small adlustable wrench or sometimes it takes an hex allen key.On the fan blade hub (center) is a hole (takes allen key) or square screw.Loosen that and lift/pull up the blades.Lock down the screw so it won't move.Chech the entire hub sometimes there is 2 screws.
Posted on Sep 15, 2010
Broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
The drum started making a terrible racket and then it sounded like something hit the floor. Now the drum won't spin. what's wrong and can I fix it myself?
need to check to see if belt is still around dryer drum. also check to see if the moter that turns the belt still works.to do this you have to take the dryer shell off.
Oct 10, 2013 | Roper Dryers
Dryer is making a terrible racket, but drys perfectly.
It depends on the noise. It could be a drum roller going bad, the idler pulley, or even something caught in the blower wheel. Can you describe the noise?
Jan 01, 2010 | Dryers
Cooler makes noise,when it rotates.please help.
Stop beating up the tower before you damage the harddisk! If the case/PSU is out of warranty, take the PSU out and get the fan replaced. You can do it yourself, just observe the arrow direction on the fan (usually the round label should point out) and wire colors (the fan should blow out). Observe also all the precautions since the capacitors inside can hold a significant charge.
Nov 10, 2009 | Cooler Master Extreme 430 RS-430-PMSR...
SHARP AR 168D MAKES A TERRIBLE RACKET WHEN PRINT BUTTON IS ACTIVATED
Hello sir; There have two possibility, first, check the fusing unit isn't the fusing roller gear broke, next very posible the clutch in drive unit is broke.
Aug 14, 2009 | Sharp Office Equipment & Supplies
2003 Xterra. Enigine making terrible racket.
start the truck and then look at all the pulleys under the hood....see if any wobble or anything also listen to see if any make noise....
Jan 14, 2009 | 2003 Nissan Xterra
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Open Questions:
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
