Question about Whirlpool Kitchen Ranges
Hi, I have a Whirlpool oven model rf386pxgb 2 , everything is working fine except the broil. I checked the cables, thermal fuse, etc. looks ok. Any ideas or sugesstions? Thanks in advance, Pablo. email: pablo_perera@hotmail.com
    Genius:
  • 1,073 Answers
With the unit set for bake check the voltage ac across the broil element
240 to element across it replace the element
no voltage across the element replace the control board
Posted on May 17, 2008
Cooking controls on left side of panel seems to not be working on Whirlpool Gold wall oven
Hello Margaret! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name phone, reviewer name (Margaret Gulan) number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 20, 2017 | Whirlpool Kitchen Ranges
My Kenmore model 950 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
Dec 28, 2014 | Kenmore Kitchen Ranges
My Kenmore model 790 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did w
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
Built-in Whirlpool model GBS307PRS01 oven won't get hot
First check the thermal fuse to see if it's open circuit and if so replace with http://www.appliancepartscompany.com/product/9223815
This is normally the problem (I have already replaced it twice on my oven).
If this doesn't solve your problem, let me know as there are some other option to try.
Jul 08, 2010 | Whirlpool GBS307PRS Stainless Steel...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Apr 21, 2007 | Whirlpool RF369LXPQ Electric Kitchen Range
Kitchen Ranges Logo
140 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
