Question about Home
The above bathroom lamp used to flicker when switched on, now it does not switch on at all. could it be that the fuse needs changing?
  • 4,340 Answers
Likely not a fuse. Sound like a fixture, bulb or switch malfunction.
Posted on Sep 18, 2010
How do I get the low beams to run automatically whenever driving instead of flickering?
if you did it yourself and did not use factory lights or ballast then it could be a voltage detection problem. If you did use factory parts then the headlight switch may have failed by coincidence. also check connections at HL plugs and or switch. ???????????
Nov 13, 2014 | 2001 Audi TT
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Slight flicker with headlights. Replaced battery which was needed. Headlights still flicker. Had changed out original lamps with brighter lamps. Could this be the problem?
Bad plugs on the bulbs.Bad grounded lights wiring.Bad alternator ground.Bad alternator charge.Bad lights switch.Also ,the new lamps may show more sensibility in voltange change or put more pressure on a older bad wiring link.
Oct 26, 2013 | 2006 Ford Mustang
No brake lights and i already changed the bulbs. for a 1984 d150
Before you did the lamp change you could have measured the voltage at the point of brake application. Now if present then check if the rear lamp assembly gets the ground connection.
if absent the brake light switch is faulty. Check the voltage at the switch point.
Also check the brake lamp fuse on the fuse box under the dashboard.
Apr 09, 2011 | Dodge D150 Cars & Trucks
Brake lights don't work, turn signals do. is there a fuse in the fuse box for them?
Thanks for choosing FixYa and welcome to the site. There is a fuse for them in the box. May be named tail lamp or back lamp. If the fuse and bulbs are good, it is probably your brake switch. It is located right above the brake pedal. It controls the brake lights coming on. It will need changed if the fuse and bulbs are good. Thanks for using FixYa.
Apr 07, 2011 | 2001 Chevrolet Venture
The lightbulb at the top of the inside of the side by side refrigerator was flickering and is now not working. How do I replace it?
First of all check on your doorr switch if the fault could be the switch. Locate it as the limit switch and press it many times to see if the light is coming on. Most often the flickering is due to the switch making the intermittent connection before the contacts burn off. So open the switch and use a good cleaning spray-WD40 maybe good and reset the swtich. If not you can open the lamp holderr inthe shelf and change. Use the correct tool to pull out the switch and lamp assembly. Hope you get this right.Good day
Aug 10, 2010 | Admiral 26 cu. ft. Side-By-Side...
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Blown fuses
please check your fuse box, it must have 22amps fuse. if not than upgrade it.
if your fuse is of 22amps or above, than my friend you have to replace your switch...............thank you and have a nice day
May 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
