Question about D-Link Xtreme N DIR-655 Wireless Router
My wireless internet quits working everytime the DIR-655 is connected, direct connect internet is OK? I recycled power to all but did not help. What should I do? What is the User Interface of the router for the DIR-655?
  • 57 Answers
Hi!
what's your modem? if you have DSL, you might need to bridge it & set your DSL UN & PW on the router..
here's an emulator i found for DIR 655..
http://support.dlink.com/emulators/dir655/
Hope this helps you a bit.. :D
Posted on Sep 15, 2010
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
My dir-655 works great via laptop wireless but the
Follow the steps below on the concerned computer:
1. Click start button (extreme bottom left corner of the screen).
2. Click Control Panel from the list.
3. Click on Network Connections.
4. Right click on Local Area connection icon and click on properties.
5. Select Internet protocol TCP/IP from the list of components and click on properties.
6. Select "Obtain IP address Automatic".
7. Select "Obtain DNS server Automatic".
8. Click OK and close the window.
if the issue persists then try changing the cable between the router ad the computer. You may also try connecting the computer direclty to the modem to isolate issue.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 21, 2009 | D-Link Xtreme N DIR-655 Wireless Router
One of my LAN and wireless network computers has no Internet
look this happens if go to your internet explorer and check if you have your internet working offline if you have it checked uncheck it
Sep 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dir 655 will not install
You should not need to enter any of that information.
The router will find the internet on it's own, once the ethernet cable is connected and the router is turned on.
Press the reset button at the back of the modem for 20-30 seconds, this resets the router to square 1. Power down, wait 30 seconds, then power back up. You should have internet connection to the router, which can be tested by connecting another ethernet cable from the router to the ethernet connector on your computer.
Reply back what your objective is in getting to the routers setup page.
Feb 04, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
347 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
