posted by sahues on May 16, 2008
how do you turn the oven pilots off. we only use one of the ovens.
Comment by sahues, posted on May 31, 2008
thank you. it took a while to locate the right screw, but it worked. it took some time to figure out where the tubing went...
1 Other User Has The Same Problem
Comment by grafixjess, posted on May 30, 2008
i am trying to shut them as well with no luck. please post some help.
Best Solution
There is tiny brass adjuster screws between the knobs on the front. Follow the tubing to the proper adjuster. Turn it clockwise to reduce it.
Rating Locked! (?) sahues has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Garland H283 Gas Kitchen Range
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
old garland H283 - need...
our volunteer ambulance corp... Answer This...
Gaffers and Sattler vintage...
After we moved our Gaffers and... Answer This...
We want to refurbish the old...
We are redoing our church... Answer This...
How to make the stove look like...
The steel is scraped off and... Answer This...
gas meter was changed upon...
it is a 1950,s clare-jewel gas... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
