Very slow start up - almost 2 minuts
The start up on this machine is extemely low.
Have tried everything I know but to no avail. Quite desperate.
  • 3,940 Answers
Here is a Microsoft article I found that has all the main steps I normally recommend in one concise article.
http://www.microsoft.com/windowsxp/using/setup/expert/northrup_restoreperf.mspx
If doing the items listed there, do not give you a satisfactory result, then you may want to look at spyware/adware as a possible cause.
Spybot Search and Destroy available for free from www.download.com is a good free tool to combat spyware.
Posted on May 16, 2008
  • 13,433 Answers
Can you tell me the specs of your laptop, cpu, memory and harddrive.
Also which operateing system are you useing?
Have old kenmore elite he3 washer. Have wet laundry after spin out. Have checked ball be low drum, replaced strainer, pump motor, cleaned all hoses. Did a test run in the drain and spin cycle. For like 7...
If the washer is taking more water during spin, then most likely it is thinking the water level is low for the load. It is a smart washer and tries to adjust water according to load. This can mean the level sensor is giving wrong sensor. I would try to run the washer with a cleaning agent (not bleach) available from specialist stores or washing machine retailers.
Also observe if the drain pump is running all through the spin cycle. If not that is likely causing water to remain. But controller is thinking there is no water and not starting the pump when required.
You should be able to locate the parts in these diagrams.
KENMORE ELITE Washer Parts Model 11049962600
Sep 20, 2014 | Washing Machines
Acer 5542 freezes
You can start by checking the Event Viewer. Right click My Computer / Manage. Check System for Errors and Warnings. They can be very technical, but most likely there is some event. Check Application as well. There is a Filter option under View. Leave Warning and Error checked.
A helpful tip.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 06, 2012 | Computers & Internet
I was driving on the highway and ran out of gas, the truck started slowing down and eventually quit as I pulled to the side of the road. I tried starting it quite a few times and eventually had a friend...
You need to start with a GOOD battery-if you do not have a charger, borrow one or buy one that has starting capability. Turn on your key and check for fuel coming out of the fuel rail (use a rag to keep it from spraying all over you/the place).-Once you determine you have a STEADY STREAM of fuel, take the plugs out and dry them off with a towel-start it up, if you have fuel, spark and the plugs are dry, it will start.
May 23, 2011 | 1995 Nissan Pickup
Need a hp light engine where could i purchase one
Sadly, there is no substitute. I was just quoted about $1500 for one (from HP), if I were to try to buy it (through a repair shop), and there are basically no parts available anymore for these TVs (everything is pretty much being recycled/refurbished, but availability is quite low).
Mar 27, 2010 | HP Pavilion MD5020N 50" DLP HDTV
1998 ford Explorer starting
check your ground cables for corrosion or looseness- it starts slow bwcause everything is still cold, after a few seconds of cranking the voltage heats the cables up and makes a better connection... also check your positive cables.
May 18, 2009 | 1998 Ford Explorer
My car is barely starting (tuning over). each time I try it gets even worse. It feels like the battery is low but nothing was left on. 2006 Nissan Pathfinder - same problem, started like a champ 2 days...
Check all your connections, make sure they are all clean & tight. Do you have a multimeter available for a voltage check at battery, before & after starting?
Jan 02, 2009 | 2006 Nissan Pathfinder
E000003-0000
Hello bungo. This code means that an area of the machine called the fixing/fusing unit which always runs at an extemely high temperature( and therefore is closely monitored) sensed a temperature error. I will gladly tell you how reset the error code which will allow the copier start fresh. As the copier starts up it will look again and the temperature and if there is a something wrong it will shut down again. This code can be caused by wierd things like electrical noise so its worth a try.Let me know if you wish to proceed as it is quite easy to reset. :->
Jan 08, 2008 | Canon imageRUNNER 5000 Copier
Garmin C340 startup
The clue is that the voice is slowing and low pitch. The main processor time base has slowed... which means everything will be buggy.
First try would be to Reset the unit. Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then reattach front cover... this is covered in the owners manual, available online.
If not, then it sounds like a hardware failure... time for a 1-800-800-1020 call (their customer service number)
Aug 06, 2007 | Garmin StreetPilot c340 GPS Receiver
Computers & Internet Logo
129 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
