Question about Sony KDFE50A10 50" HDTV
The bulb going 3 times in four years can this happen or can it be a manufactor fault
    Sergeant:
  • 171 Answers
Well to be honest with you it could happen if you purchase a generic bulb they will only last around 1year to 1.5 years always buy Philips the other problem that you may have could be the ballast board if for any reason it is sending to much voltage to the lamp it will make the lamps burn out much faster
If you want to fix this problem I would replace the ballast board ( around $60.00dls - $80.00dls) and also replace the lamp ( $115.00dls - $140.00dls ) this store has the Philips lamp
http://www.discount-merchant.com/SearchResults.asp?Search=KDFE50A10
Posted on Sep 15, 2010
  • ABRsvcs Sep 15, 2010
    Lamp life is based upon usage hours not calender time. If the set is heavily used, than it is possible that your replacement period is correct. It is possible too that the ballast is slightly defective and is causing excessive stress to the lamp. This is extremely rare however. Check to be sure that there is proper ventilation for the lamp. Its lifetime is shortened quite a bit if it runs hot. It may not be hot enough to trigger a temp shutdown, but may be hotter than standard. Cleam of the vents and make sure that the fans are all turning properly as well.
    Dan
Mitsubishi WD-65733 Lamp, Ballast, or Other Problem
What do you think should be right. If there any loose solder terminals to the ballast bard, this type of fault can occur. Anyway, I'm not sure about it; but check this frist before doing any other. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi WD-65733 65" HDTV
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
I got a problem with my pc it will always shut off when i streaming videos or playing browser games...can yo please tell me what could be my problem is?i already changing my power supply 3 times it doesnt...
hey, most common faults usually overheating with that fault, restart the pc, go into bios usually by pressing del or f2 button on the black screen and look up hardware monitor tab and check the cpu temperature if its around 60c that will be your problem, and will need a new heatsink and fan fitted.
other thing to do is hard drive test you will find the diagnostic tool on the manufactors website.
Jun 16, 2012 | Computers & Internet
I have a 4 year old Toshiba-56HM195 with blueish haze.I have place the engine light 3 rme in 3 year bulb 3 time in 3 year it's been a year seen I dn it which one is going out .
Yuor covergence board is bad and you need to have a tech replace the convergence IC's on the board and bad electrolytic caps, or buy a new one at www.partstore.com
Nov 26, 2011 | Toshiba TW56X81 56" Rear Projection...
I have a mitsubishi wd-52631 approximately 3 years old have had to replace the bulb 7 times is there a malfunction in these televisions that should be fixed to avoid having to keep replacing these...
You have a problem that is destroying your "Bulbs" this is NOT normal at all. This is indeed a problem when people aren't experienced enough with technical matters. You see the "Bulb" is a Symptom, of the actual "Fault" NOT the main cause. This, "main cause" MUST be fixed FIRST, before one replaces anything, otherwise what you are experiencing, will simply happen over and over again, and gets more expensive that if one had of sent it to a reputable service centre/man in the first place. We really ARE worth our salt.
Feb 12, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Driver-side headlight bulb burns out every four months or so. Passenger side is fine - same bulb for a few years now.
Hi:
four months is way too soon, so you need to look things over a little closer. The entire headlight assembly could be slightly loose, and vibrating on bumps and causing the bulb to die. Next time you put a new bulb in, buy and use some dielectric grease on the contacts of the new bulb, to keep moisture out, and examine the harness plug for signs of dust, dirt or corrosion. since it takes four months to fail, it has to be a minor thing.
Nov 24, 2009 | 1999 Toyota Corolla
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung rear projection
If the shadow is only red, you can check your convergence and see if aligned first and then, check to see if in red bias my need to be turned down a bit.
Dec 13, 2007 | Zenith D61W25 61" Rear Projection...
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Sony KDFE50A10 50" HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
