Question about Westinghouse Electric L1916HW 19" Monitor
Hello i have a 19'' white westinghouse lcd computer monitor and it all white, is there anything i can do, i have already checked the green board and capacitators and what not and eveything tested fine, is ther a trick to fixing this???? model###is. L1916HW
  • 732 Answers
Chapp29, You didn't tell me the brand name of the electrolytic filter capacitors that are on your monitors "switch-mode-power-supply / cold-cathode-fluorescent-lamp-ballast" circuit board. How did you measure (check) the capacitors? Are any of the rubber seals pushed out of the bottom of any capacitors? What is the "date of manufacture" of this unit? Will L1916HW work connected to a different "known-good" pc? Will "known-good" monitor work ok when connected to your pc? 12fixlouie
Posted on Sep 15, 2010
I have a flat panel lcd 19, it doesn't power on
Don't know what model you have, but I would check the fuse first. It should be marked with a Fxxx where xxx are numbers. Sometimes the fuses are glass, others times they look like little surface mount chip types. If you find that a fuse is blown, does not mean that just replacing it will solve the problem, you need to figure why the fuse has blown, typically the FETs short out. Hope this helps.
Jul 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
I am powering up and the flat screan turns on and
More likely to be bad caps (bulging top/seal) in the power supply, which when they failed, they may have taken out the inverter fuse on the transistors in the inverter circuits also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
ViewSonic VX900 was working fine. I was in the midst of shutting down the computer/monitor and the electricity flashed off, then back on. My monitor turned white, I played with trying to get the green...
The power board in your monitor was damaged when the power was interrupted. We can do the repair for you if you are interested. The repair charge runs $35 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 18, 2009 | ViewSonic VX924 19" LCD Monitor
Monitor stays white, cannot get picture
U might have problem with ur VGA cable. It may be loosely plugged. Plug it tight
Jun 24, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Backlight out
hi..The board that drives the backlights might be defective
and board will need to be replaced.
check it out..
thank u..
kindly rate my response..
May 06, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Audio and picture quit working on white westinghouse lcm-17v8
If you haven't figured it out yet through a web search, Westinghouse monitoris have problems with blown caps on the power supply board. If you are lucky the problem is minimal and won't require more than replacement of the caps. You won't know until/unless you open the case and inspect the power supply board.
Dec 23, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
E19t5w screen problem
Hi...there,
Well, there are 2 things that caused thing problems... You've got a busted panel or you need to replaced a new AD Board.
Nov 30, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Westinghouse Electric L1916HW 19" Monitor Logo
184 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Tom Chichester
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
