Question about Epson PhotoPC 650 Digital Camera
I have Epson Photo PC 650 digital camera. It is not working. Power is not on.
  • 101 Answers
To be honest I think the camera, although great in its day has given you good service, unless changing the batteries or gently pulling on the camera contacts to make them give better contact with the batteries works I think that it is what is known as 'beyond economic repair' I. Even. Time to buy a new camera. Sorry to be the bringer of bad news.
Posted on Jul 03, 2014
5 Suggested Answers
pishta68
  • 593 Answers
SOURCE: EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Posted on Feb 22, 2008
SOURCE: Umax AstraPix 650 Digital camera driver
thanx fdskjkjdsfkljjdsflfkjgf fj kljjlk ;j;lkdj hgkj hj h dvshj hdf
Posted on Jul 26, 2008
  • 105 Answers
SOURCE: Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Posted on Oct 08, 2009
SOURCE: manuel for Epson photo pc 8502
i don't usem m340 digital camera
Posted on Feb 02, 2010
I have the first Epson Photo PC Color Digital Camera and I just purchased ANOTHER Camera/Computer Connector. The problem is that the download on Epsons Site isn't use with Windows Vista only Old
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Apr 12, 2012 | Epson PhotoPC 650 Digital Camera
I recently purchased an Epson Photo PC 3100Z Digital Camera (used). It appears to take pictures but does not store in on the memory card. A code 181 flashes in the top display window. The memory card is...
It is probably having trouble with the capacity of the memory card. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
You don't say what type of memory card you have. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 22, 2011 | Epson PhotoPC 3100Z Digital Camera
Manuel for Epson photo pc 8502
Feb 02, 2010 | Cameras
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
I've lost my installation cd for my EPSON photopc 2100Z. HELP !!!
you can try here. you have to choose photo viewers and cameras and then in the next one choose your camera and the last you put your operating system. hope it works
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D
Feb 20, 2009 | Epson PhotoPC 2100Z Digital Camera
3000Z and Speedotron Flash power pack
You also may have a faulty hot shoe adapter or pc cord. Check them with an ohm meter, or with an old 35 mm camera. Or just short out the hot shoe contacts with a piece of metal and see if the strobes flash.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
CompactFlash storage card
Make sure you're using an ATA-compatible CompactFlash memory card. Other cards may not work with PhotoPC 650.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Area captured different from viewfinder area
Make sure you look straight through the viewfinder. Keep in mind that the area visible through the viewfinder is slightly smaller than the area captured in the photo. If you're taking a close-up or macro mode picture, turn the camera dial to the LCD mode so that you can use your LCD screen to preview your picture.
Windows NT 3.51
No, Windows NT 4.0 is the minimum NT operating system requirement.
Red-eye reduction in macro mode
The red-eye reduction feature causes the flash to blink on and off rapidly, then flash normally. This may cause over exposure and subject discomfort in the macro mode.
Open Questions:
I just bought an Epson 650 digital camera. I know, it's not new and fancy, but it's all I could afford right now. I bought this one (from ebay) mainly because my daughter has the same one- she bought several years ago, for around$350. I've noticed what big, clear, detailed pictures it takes (she sends to me). She resizes the pictures smaller, but the resolution on hers is 144. she uses one of the "better" settings, not the standard and not the BEST. What I've noticed with mine is, the resolution is 75 and the pictures don' tseem as clear and detailed. This might be partially because the scenery ones I've taken are of SNOW. I've tried using all the settings, even the very best, which only takes 3 pictures. The resolution is still 75. The picture size is big, 15"X 11". They are JPEG. I tried using he HotShots software that came with it, and now use Paint Shop Pro 7, with AQUIRE (Twain). I tried using the memory card in the USB cable that came with it, but it seemed to be clashing with my CD burner, which is in the other USB port. It's just as easy to use the camera and serial port and PSP. My daughter doesn't know much about it, she just takes the pictures and then takes them off. Hers have always been 144 resolution. I'm not saying the pictures on mine aren't good, and they're better than the Kodak DC 3200 I've had for over a year. Just that they don't seem as good as my daughter's, and it's the exact same camera. Could it be the memory (flashcard) that sets the resolution of the pictures? I have the original 8 MB one that came with the camera and my daughter once bought a bigger one. I know I can change the resolution in PSP to something higher if I want. I've been trying to find out what decides what the resolution of the pictures (when taken off the camera) might be? I can't find anything in the directions book about the settings for this. Just the "standard, better, best and extra fine". But, they all take pictures with 75 resolution.
Feb 27, 2017 | Epson PhotoPC 650 Digital Camera
Epson PhotoPC 650 Digital Camera Logo
Top Epson Cameras Experts
Steven Wander
Steven Wander
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you an Epson Camera Expert? Answer questions, earn points and help others
