Question about Numatic HVR200P Bagged Canister Vacuum
I have taken the hi lo switch wires off and can not remember wich why they go back on can any help thanks
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
Oreck vacuum repair manual
Unless you have a foot switch, the on/off switch for most Oreck vacuums are up in the handle. You will have normally 6 screws that hold the handle halves together. Take the screws out and then split the two halves apart and you will find the switch inside at the top front of the handle. You may have had a wire come off of the switch and it just needs to be plugged back onto the switch and then you can re-assemble the handle and you should be back in service. If you have a foot switch, you might need a meter to check continuity throughout the vacuum because you may have a broken wire somewhere. Hope this helps you solve your problem.
Jul 20, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How do i bypass pcb board on a henry numatic international"?"
You will need to remove all the wires off it and off the hi/lo rocker switch. Then disconnect to two wires on the opposite side of the on/off to the power in side. The two white motor wires then get connected to this switch. The machine will now run on high speed only when turned on.
Jul 06, 2014 | Numatic Henry Bagged Canister Vacuum
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
I am trying to change an old fashioned fuse, (house lights), luckily had a spare one. Have put the 15amp fuse wire through the whole thing, and trying to describe if I've got it right is alitle awkward,...
hi.
your descriptions are understandable and sound about right.
as long as the wire is securely fixed to both pins, you should be ok.
if there are any problems, especially if the fuse blows again fairly soon, then i strongly recommend calling a qualified electrician to check the system.
Apr 04, 2011 | Vacuums
My Dyson DC 24's beater bar switch didn't actuate and the beater bar didn't turn. When I brought it to a certified serviceman he told me that a wire interferred with the switch and all he had to do was...
Hi- I had the same experience but it turns out there's a small trip switch if you've taken the brush out to clean it, it needs to be reactivated by pressing the small red button to the right of the brush... took me a year to figure this out! Been meaning to get in touch with Dyson. Not sure if this is the same problem that you have.
Nov 28, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Dec 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Wiring foot pedal switch legend II
If I remember correctly,on the switch itself,each connector is letter coded.'W' for white,'R' for red,and so forth.The manual mostly talks about how to change attachments and basic operating,but not repairs.
Dec 20, 2008 | Kirby Heritage II Vacuum
Eureka boss vacuum, model 4331
it is posible you do not need the other wires have you replaced the original switch for the same or similar some of these switches have lights on could this explain the extra wires? also vacumcleaners sometimes have interferance surpresors they work fine without these but they interfear with tvs etc if not fitted mabe its missing?
Jul 19, 2008 | Kenmore Progressive Bagless Upright with...
Numatic HVR200P Bagged Canister Vacuum Logo
32 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
