Question about Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3
Drill Batteries won't stay charged for more than 15 minutes
1. Your batteries may be too old
2. Some of your batteries cells are bad
3. The charger may not be producing full output
Try dis-assembly and check each cell individually-Bad cells can be replaced at a fraction of cost of battery replacement.
Posted on May 23, 2008
Tip
Cordless power tools
To maximize your battery life let them cool down 15 minutes before you put them on the charger.Also let them cool down after charging before use for 15 minutes.Store your batteries with a full charge and condition them every month by using them a little bit and return them to the charger for a full charge.
on Oct 20, 2010 | Drills
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
14.4 volt cordless drill --- yelloow and green light on lo0nger than 15 minutes, cannot find user manual.
The battery will no longer take a charge. Time for a new one. I had 2 like this in the last month. The batteries where 5 years old and been charge for over 800 cycles each. Age and cycles will wear them out.
If the tools is still good jsut get new batteries. But check the prices. I just bought a new drill and saw set for $90 and 2 new batteries were $60. I got a new set, since the drill was 8 years old and worn out.
Jun 30, 2011 | Ryobi Drills
I used my makita 18v 1/2" cordless drill then charged it and put it away. When I tried to use it again a month later there was no power. I tried to recharge the battery but red light would only stay on...
WOW! Count yourself very lucky. Most batteries don't last half that time. The newer battery probably has a lower amp hour rating than the first one. When replacing the battery (and you must replace it) look for the one with the HIGHEST amp hours - which is usually written on the battery or packaging. You can also ask at a Batteries Plus store if they can re-build the original battery for you- since the unit is so old, and Makita might not make replacements for your drill. You could rebuild the battery yourself,it is only 12 AA or C batteries wired together, but ni-cads can be dangerous when soldering and can explode if you slip up. Best bet is to get a new or rebuilt battery.
Jul 02, 2017 | Makita 18V 1/2"CRDLS Drill Kit
Both green and yellow light stay on and batteries will not charge 18v
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
Battery charge problems Ryobi 18v
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
Jan 16, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Logo
197 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
