Question about Sharp AR-BC260 Color Copier
Sharp ar-bc260 working on a sharp ar-bc260 lines on image transfer belt also found broken part in feed tray 1
    Problem Solver:
  • 6 Answers
Change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
Posted on May 17, 2008
  • Mick May 08, 2009
    Take it to a river, and see if it will float?
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
When trying to print, get error message to load paper into bypass tray. All printing preferences have the input tray as tray 1?
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
Dec 09, 2009 | Sharp AR-BC260 Color Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
Sharp AR BC260 color printing Lots of ghost lines in color prints
depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Nov 19, 2008 | Sharp AR-BC260 Color Copier
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Switch the way the paper comes out of the machine
Sounds like your tray settings are incorrect. Make sure that if the tray is set to 8 1/2 X 11 in the menu settings(not 8 1/2 X 11R) that the paper is set in the tray to feed the long edge first. The machine is capable of automatically rotating the image to fit the paper as long as the paper is set correctly.
If you prefer to feed short edge first then set it for 8 1/2 X 11R.
Oct 14, 2008 | Sharp AR-M205 Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Reducing
insert original in doc feeder, then select cassette thst has the paper size you require, auto image button appears on display press it and it will self calculate.
Dec 19, 2007 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
186 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
