Question about Mtd 22" Yard Machine Push Mower
I have a 20 inch MTD rotary mower (type 0341E1) with three fixed cutting heights. The lowest height is to high. I changed wheels but they are to low. Can I buy a quarter inch spacer between the blade adaptor (drive shaft) and the blades?. Steve Australia
  • 1,631 Answers
You can always "MacGyver" or "Tim Taylor" anything. Modifications are always being done by some one or another.
Thats how the right thing get made, or invention comes around.
If you think your idea, which sounds like it will, will help you and your problem, go for it.
Just be careful and keep it safe.
Posted on Mar 09, 2015
panilling9
  • 284 Answers
SOURCE: Yard Machines 22 inch mower, I dumped it on its
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
Posted on May 25, 2009
moretons
  • 155 Answers
SOURCE: I am working with a Murray MTD Pro 42
try this link it may helphttp://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
Posted on Jul 27, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
rwvanlue
  • 486 Answers
SOURCE: manual for mtd 30 inch ride on mower
model number of mower from ID tag and then go to
www.mtdproducts.com
Posted on Nov 10, 2009
  • 78 Answers
SOURCE: how too replace the blade drive belt on a murray
Its actually really easy. First, determine the size of your mower deck. Is it 30" 42" 54" etc. Then, go to a home improvement store like Lowes or The Home Depot (or an online retailer.) Search for a replacement belt for your deck size. Removing the old one is easy. Pry back the retainers on the engine pulley and slip the belt off of the pulley. This should make it very easy to pull off the mower deck. Installation is the opposite of removal. Make sure you note the belt arrangement for proper installation. Good luck!
Posted on Jul 10, 2010
How to lower lawn mower
Cindy, if it's already at the lowest setting, you kinda / sorta answered your own question, i.e. it can't be adjusted any lower; but, as you may be aware, there is an adjuster at every wheel, and by putting all wheels at the same - lower - level, you will get a lower, mowing height; and if you've already done that, or there are no 'individual adjusters', they wheels are typically bolted to the frame and there are usually several holes to bolt the wheel to - simply un-bolt and re-bolt to achieve the lowest, preferred height.
Apr 01, 2016 | Garden
How to adjust the height of the mower
If you mower does not have adjusters on the wheels then there should be three holes where the wheels are bolted onto the base. to adjust these you have to take each wheel off and bolt them in the same hole for each wheel. The top holes are the lowest the mower can be set the middle ones bring it up part way and the bottom hole is the highest setting. You should set the mower to cut at least two and a half inches above the ground. The center holes should be good.
May 12, 2014 | Black & Decker 19" Electric Lawnhog...
How do I Lower my yard machine mower to cut grass shorter?
there should be adjustments on each wheel.
Place the machine on a flat level surface and adjust each wheel so the blades are at the height you want it to be. Make sure all the wheels are all at the same height. Usually, the bottom of the deck lip to the floor equal all around.
May 05, 2014 | Mtd 22" Yard Machine Push Mower
What is a good height for an office chair?
office chairs range from 14.5 inches all the way up to 23inches. A good height is around 19inches. Usually chairs have a lever thatallows you to raise and lower the height as you wish.
May 29, 2012 | Furniture
The hover fly mower sits on the grass, being that there are no height settings, it cuts quite low. Are there way's to make the mower sit higher off the ground in order to cut the grass at a higher...
Usually all mowers have height adjustments of some kind. Look around your front and rear wheels, if you have a number of holes drilled into the deck ,these are your adjustment holes.You would unbolt the wheels and put them at the height you would like.
If as you say there is no adjustment, I would say buy new wheels that are an inch or more bigger than your present wheels and install them in place of your old wheels. If you go to any local dealer they will be able to help you with your problem.
Jul 03, 2011 | Garden
Need to know how to properly set the guide wheel heights on the mower deck and the blade height for proper mowing heights.
with a marker,mark on the front of the deck where the blade height is, and do the same on the back, do this so you can get your measuring tap in there.play with the adjustments till you get the front and the back the same height,it should be around 5 inches florida up north 3-4 inches. it is hard to find a mower that can be set for 5''. the shorter you cut the grass the more watering it requires. check your grass type and search it's cut height and food requirements for you area or growing zone, for a happy healthy lawn.. jay the pump repair guy in longwood Florida
May 26, 2011 | John Deere 26HP Hydrostatic 54" Riding...
Black and decker 18 inch flip over handle electric lawn mower cat #8019 don't know how to adjust height it is cutting way too low
There is no height lever on this simple mower. To change the height of cut, the wheels themselves must be moved up or down. First, unplug the mower. Turn it over on its side. You'll see that the wheels attach to the frame with simple bolts, and that there are two open holes at each wheel (three holes at different heights altogether, but one of the holes is occupied by the current mounting height of the wheels). Undo each bolt for all four wheels and move them to a new position. Note that the wheel-mounting holes are drilled 5/8-inch apart from each other. If you want to add another hole there is room on the sheet metal to make a new hole for each wheel, and this would put the mower body and blade very high off the ground, if used. You can make that new hole for each wheel with your electric drill. But I think your mower is probably set to the lowest of the three holes, so see first if moving the wheels 5/8-inch higher is better for your lawn, and, if not, then use the 1 1/4-inch higher set of holes on all four wheels. Make sure to move each wheel to the same height hole! Good luck, be safe. --Joe, Tucson, AZ
Apr 30, 2011 | Garden
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Mtd 22" Yard Machine Push Mower Logo
80 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
