Question about NorStar Startalk Flash 2 Phone
I want to delete the existing greeting message with a new message on the autoattendant. How do I do that ?
    President:
  • NorStar Master
  • 860 Answers
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. Once you have entered the password you will see 3 selections you can make .Use the three soft keys under the display and select AA (auto Attendant). Next, press greeting and greeting again. Next, it'll ask for the greeting number your probably working with greeting 1. Press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Posted on Sep 15, 2010
Testimonial: "Chaned automted attendent no problem easy to follow instructions"
I want to delete an existing greeting message on the autoattendant. How do I do that?
Okay, it sounds like you're using a standard auto attendant greeting setup.
Try this:
Feature 983
Password: 1020000 (or whatever you have recorded for the password)
Select AA
Select Greeting
Select Greeting again
Enter 1 (for Greeting 1)
You can hit Play to ensure that you are listening to the correct greeting. If not, select another greeting by enter the number 2 for greeting.
Once you have found the greeting that you would like to erase, simply press record and let it record one or two seconds of silence. The greeting will be gone. Press OK to accept the new greeting (silence) and exit the system.
May 13, 2014 | NorStar Startalk Flash 2 Phone
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 | Avaya 1408
How do I record a greeting on the Uniden cxa/5698?
With the phone in standby, press [greet]. While the preset message is playing, press and hold [greet] again. You will hear the announcement "Record greeting" and a confirmation tone.
If you already have a greeting recorded, you can delete the current one and then record a new greeting. While the current greeting is playing, press (delete). And then start over with the first.
Start recording your message. You will have thirty seconds, and the message counter will count down.
When you are finished recording your greeting, press [greet], (play/stop) or [set]. You hear a confirmation tone, and then your greeting plays back for you.
The full instructions begin on page 45 of the manual.
Jan 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I lost manual. I need to know change message when will be out of town answering message.
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Dec 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do i change my vociemail message for the Dect 6.0?
Reording a Personal Greeting Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting.
To keep this greeting: Do nothing.. To switch to the other greeting: Press 6 while the system is playing the current greeting. Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last greeting you hear is used as the current greeting.
Deleting Your Personal Greeting You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous section to switch the greeting.)
While the personal greeting is playing, press 4. The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Oct 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Recording a Personalized Greeting
Press and hold greeting... it will ask for a new greeting... Record new greeting and then press greeting button again.
Feb 25, 2010 | Uniden 5.8GHz Cordless Phone
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to change voice message on i560
  1. Access Voicemail
  2. You will be prompted to press:
    1 To Listen to new messages, or
    2 To Record and send a message.
    You will not be prompted to set your Greeting at this point - press 3 to Access Phone Manager.
  3. Press 1 for Personal Options.
  4. Press 3 to Record a Personal Greeting.
  5. To record the Busy Greeting (when you are engaged) press 1 or to record the Standard Greeting (all other occasions) press 2.
    Your existing Greeting will be played to you.
  6. Follow prompts to record a new Greeting:
    To Start press 2
    To Stop press 2
    To Save press 5
    To Review press 6
    To Delete press 4
    To Exit press * until system says "Thank you for calling".
Let me know if this will help
Nov 30, 2009 | Motorola Mobility i560 Cellular Phone
Partner 18 - voice mail greeting
Hi Smr. I ran into the same problem. I found out that ASA means auto answer. My phone guy said its rarely used anymore becuase autoattendant does so much more. you get the message when you enable (or in my case) access anything that needs the card. I did it by accident by hitting intercom 891.
I found a thread that suggested a system reset that worked ... and (I confirmed ion page 4-55 of my manual) it doesn't erase any settings ...but it does disconnect any calles in progress.
In case you don't have the manual here's the procedure (which I just did minutes ago)
hit "feature", "00" , then "#728"
Sit tight about 10 seconds and all should go back to normal.
email me if you have uestions or need a copy of the manual.
danland@sbcglobal.net
Nov 16, 2007 | Lucent PARTNER18 Corded Phone
NorStar Startalk Flash 2 Phone Logo
366 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
