Question about Arrow ET200 Electric Brad Nail Gun
The nail 1 1/4" going in only 1/2", how can I fix it? material 3/4" plywood 1/2"drywall
  • 43,501 Answers
Some of those guns have a dial or thumb knob that adjusts the pressure....try to find it and spin it to a higher number... if you do not have that or it is all the way up then the gun is going bad... which they do often... they do not last very long...
sorry I can't give you better news other then that...
heatman101
Posted on Sep 15, 2010
How to fix 1 inch holes in drywall
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Apr 06, 2016 | Drywall
How can I fix tile backer to honeycombed drywall
Get you some heavy duty liquid nail or similar adhesive, put it in strings/loops, wait a bit, put rock on, hold a bit done
Mar 15, 2015 | Drywall
My 2012 wall air condioner is leaking. How do I fix this and repair the drywall?
It sounds like the drain line is plugged where it goes outdoors, so water is backing up inside the unit until it spills over indoors. Clear the drain line.
You may need to cut a section out of the drywall where it's been damaged, then get a matching piece of new drywall to replace it. If you can cut down the centers of two studs, all the better - then you can screw the new patch directly to the studs on both sides. If not... at least leave yourself a couple of inches of drywall to stitch to - you can do that by screwing small pieces of plywood to the existing drywall, overlapping the hole. Then you can screw the new drywall patch to the plywood.
Next is your adventure in taping & mudding & sanding the drywall to finish the patch. Last, paint it to match the rest of the wall... or repaint all of that wall, including the patch. No need to paint adjacent walls, if your color matching is pretty close.
Jul 26, 2014 | Samsung MH052FNCA 18000 BTU High Wall 410A...
GUN FIRES BUT NAIL DOESN'T COME OUT
I am assuming the driver travels down but misses the nail, if so the end of the driver pin may be worn, a quick fix is to touch the end of the driver on a grinding wheel to reface it, ensure you remove the least amount of material possible to maintain the driver length, if this doesn't fix the problem you may need to replace the front plate
Jun 27, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
Mar 09, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
Can i use 1 and 1/2 inch nails to nail 3/4 inch hardwood.
The only time you would use 1 1/2" nails for 3/4" wood is if the flooring is being place on plywood over concrete.
Dec 05, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Does nails have to penetrate a plywood deck
Just so the top of the nail head is flush with the top edge of the plywood. I hope this helps
Oct 26, 2009 | Jensen JER-422 Universal Remote Control
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
Aug 21, 2009 | Stanley Factory Reconditioned Bostitch...
Arrow ET200 Electric Brad Nail Gun Logo
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
