Question about Galaxy Radios DX-93T Base CB Radio
Can cigarette lighter plug be used for 93t galaxy radio?
    Guru:
  • 773 Answers
Yes, but be very careful of polarity. If you hook it up backwards the radio will stop working because it will blow the polarity protection diode.
Posted on Oct 07, 2010
To charge
Radio shack sells "splitters" that have 2 cigarette lighter outlets with one plug. About your only option.
Jul 09, 2013 | Cobra Microtalk 100 FRS Walkie Talkie...
I have a galaxy 93T cb radio where on the circuit broad can u ajust the static noise
you can adjust the noise but its probably more a filter problem then anything. If you change the filter to one with more rejection then you should be good. the noise is probably normal anyway
Jun 15, 2012 | Galaxy Radios DX-93T Base CB Radio
How too reduce the static noise in a 93T galaxy radio
doesn't make a difference what radio,if you have static it will be in them all . Buy yourself a noise clipper ,about 27 $$$ and that should help you with the static.
Shorted out cigarette lighter in mercedebenz
You should replace both your battery and cigarette lighter.
Apr 01, 2012 | Mercedes-Benz 400-Class Cars & Trucks
I would like to replace the stock 2SC1969 bipolar transistor with a ERF2030 mosfet transistor in a Galaxy 93T.Can anyone tell me if any caps need to be removed on the amp board since C203 and L33 are not...
The radio you listed "Galaxy DX-93T Base CB Radio" utilizes a 2SC2290 final transistor. This is not a T220 2SC1969 and you cannot install an ERF2030. This is a round and white looking transistor. Replace it with only the same transistor.
Mar 11, 2011 | Galaxy Radios DX-93T Base CB Radio
The 93t have a output problem
hello this is probably down to the finals/pa transistor have given up you will find these on ebay iff you can fit them yourself goodluck
Jan 26, 2011 | Galaxy Radios DX-93T Base CB Radio
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Looking for an owners manual for a galaxy II radio. cant locate on the net.
Contact the Good Folks at (706) 270 3829 they have them available.
Sep 09, 2010 | Galaxy Radios DX-93T Base CB Radio
Cigarette lighter and radio went out at same time on 2002 accord
Check fuse 9 15amp ,this controls ciglighter/radio
Fuse box located glovebox area,check owner manual for location
May 22, 2010 | 2002 Honda Accord
Radio and cigarette lighter
You can pull the fuses one at a time and look at them.You will know the bad fuse when you see it.
Sep 02, 2008 | 1992 Mazda MX-5
Galaxy Radios DX-93T Base CB Radio Logo
93 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
