Question about KitchenAid K45SS Classic Stand Mixer
MY kitchenaid mixer has always oozed oil but suddenly today I can no longer attach the dough hook. The spring doesn't want to move enough for me to attach it. It was fine yesterday.
  • 19 Answers
The oil that is "oozing" is actually grease. If it is laying on its side the grease will leak out but isn't really an issue. If it is leaking while the machine is right side up, it usually means you have a problem with the seal. When it comes to the spring not bending allowing the attachments to lock onto the shaft, that is a bizarre problem as the spring is just tension and isn't internally attached to anything inside the machine. If you want you can replace the planetary gear but that seems a bit drastic just for the spring. We usually recommend 1800Parts for parts and accessories because they carry EVERYTHING! So the seal they might have but I would bring the machine to someone to look at the planetary gear to make sure everything is in working order. If you are in New York you can bring it to us.
Posted on Sep 15, 2010
  • tomnrose Dec 20, 2010
    My mixer also oozes grease, when right side up. Another problem I'm having is that the motor head starts to shake side to side when I increase the speed and not because the batter is too stiff.
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Bread dough beater will not come off
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
I cannot remove the flat mixing blade, after mixing cake. It has never happened before, just doesn't move up down or sideways! it seems completely locked.
The blade sounds like it's jammed somehow perhaps simply with some food matter.
Ensure the mixer is not plugged in then try removing the bowl, locking the mixer in the down position and pushing up hard on the blade to try and dislodge it. If it comes free and lifts up then try wiggling and rotating it normally off the mount.
Sometimes with use the attachments can become slightly warped requiring more force to lift them before rotating off the mount.
I once used my own Kitchen Aid mixer with the dough hook attachment to make a whole wheat bread dough. When I was done the hook was a bit bent from the hearty dough. There was also some flour in the mount causing it to jam. Removing the hook attachment proved difficult but not imposable.
Good luck.
Apr 18, 2011 | KitchenAid Food Mixers
KitchenAid stand mixer KSM50PWH. Was kneading dough with dough hook attachment and it quit turning. Motor works fine but the part that's supposed to go round and round doesn't. Can I fix this?
The Nylon Worm Gear has stripped. This is designed into the part so if the Mixer gets overloaded, it won't burn out the motor. Which is odd if you have the reset switch like I do.
Part# 4162897
You can buy it online at Kitchenaid.com
Jan 17, 2011 | KitchenAid Food Mixers
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
May 14, 2010 | KitchenAid KP2671 Professional 6 Series...
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
Jan 03, 2009 | KitchenAid Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
517 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
