Question about NEC PlasmaSync 61MP1 61 in. Television
Just a half picture on the screen
My plasma only shows half picture
  • 1 more comment
  • Anonymous May 31, 2008
    ony haf screen
  • Anonymous Jun 06, 2008
    just show half screen at bottom
  • Anonymous Nov 08, 2008
1. Remove the rear cover 2. remove the perforated large shield on the main board housing (almost in center). 3. Unplug the right top fan and temp sensor plugs ( two small plugs at the top of the main board). 4. Remove screwsthat secure the main board housing, there is also four screws by the video inputs. Do not unplug the board, just gently pull it away 6 to 8 inches. 5. Remove the cover with the Top fan attached (more screws). 6. Now the scan board for the top half of the screen is exposed. The board has four large heat sinks with two large Electrolytic aluminum caps next to each heat sink. 7. The problem caps are at the very top right side of the scan board C192 Nichicon 220 uf next to the IC, the other cap is C120 100UF on the lower side of the IC next to a heat sink. I replaced them without taking the board out. C192 is the one that failed, the other one tested OK but I replaced both.
I got the caps from Mouser.com they are 69 cents each, the Mouser part number for the 220Uf is: 647-UUD1C221MCL1GS (Nichicon 220uFm 16V 6.3x7.7 mm surface mount); the 100uF is:647-UUD1E101MCL (Nichicon 100uF 25V 6.3x7.7mm), both are 105 degree C. I bought two extra spares in case I need them for the future.
Reassemble the unit in the reverse order and you are done. Note if you test it without closing everything, make sure you have the main board shield back on, otherwise the screen will bleed due to the noise from the board. good luck! mine has been working fine.. just like new..
Posted on Aug 29, 2008
I have the same problem, except it is the bottom half of the screen missing on a PX-61XM1G Plasma Monitor. Any suggestions?
Posted on Jul 30, 2010
    Problem Solver:
  • 10 Answers
Or you can buy a new board from ebay..http://cgi.ebay.co.uk/Common-Driver-Board-for-NEC-61MP1-Plasma-942-200462_W0QQitemZ200353525307QQcmdZViewItemjust a half picture on the screen - 4e35703.jpg
Posted on Oct 05, 2009
  • wolf1e Oct 20, 2009
    Ryan5081
    is this the same board mate if not i will delete picture hope this in some way helps ... thanks
Only half screen showing
Posted on Jul 18, 2008
It's lcd's complaint
Posted on May 16, 2008
2 Suggested Answers
techman007
  • 1112 Answers
SOURCE: plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
Posted on Sep 27, 2009
Samsung plasma tv picture trouble. only bottom half of tv is showing a picture. Top half is different colors and no picture.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 08, 2015 | Samsung Televison & Video
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Norcent plasma had smell of electrical burning and
get real bright flashlight shin close to the screen in dark roomand try to push the menu button if its the bulb you'll see some picture with flash light shining that shows your backlight is out
Feb 15, 2010 | Norcent Technologies PT-4291HD 42 in....
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Feb 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
NEC PlasmaSync 61MP1 61 in. Television Logo
793 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
