Question about Microsoft Windows XP Home Edition
I just installed a new motherboard into my computer. i have installed the mobo drivers and have no ! in device manager. but still no sound
    President:
  • 2,291 Answers
Turn off ur pc and remove the cell and put it again and turn on and run registry cleaner reg in out and then check it
Posted on Sep 17, 2010
Why is it there's no need to install mobo drivers in windows 7?...unlike windows xp.
which motherboard are you referring to all motherboards need drivers to function
click start right click on computer select properties then device manager you will see a list of all devices on your motherboard
if you see a yellow question exclamation mark or a red X a driver needs to be installed
if you expand these then right click you will see options to update driver
hope this helps you
Mar 09, 2012 | Computers & Internet
The computer is not producing any sound from the speakers
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
Sep 02, 2011 | HP Compaq dc7600 Small Form Factor PC...
I need sound n VGA driver for my mobo ms6580 ver - 5
virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 25, 2011 | MSI MS-6580 Motherboard
I have no sound coming out of the monitor speakers
  1. Right click my computer, and select manage.
    Click on device manager. Can you see any yellow question, or exclamation marks next to your sound devices?
    If so, try re-installing your sound drivers.
    If you have onboard sound, then you can get the sound drivers from your mobo(motherboard) manufacturers website.
    If you have a separate soundcard, then you can get the drivers from the soundcard manufacturers website..
Oct 21, 2009 | Computers & Internet
Cant get sound card working in Windows XP Pro 64 bit
Go to Add/Remove Programs and uninstall the software related to your soundcard.
Go to Device Manager and remove the sound card it is the device that has an exclamation point or question mark.
Turn off your PC and remove the Card. Then turn it back on again and enter the BIOS setup and disable the built in sound card of your motherboard then press F10 and save the changes.
Restart your computer and verify that windows is not going to scan for missing devices. Check the Device Manager again and look for any devices that has an exclamation point or question mark. If there is none. Turn off your computer put the sound card back in and turn it on again. Put in the CD Driver but exit on the autorun let windows detect the card automatically and wait for it to ask for the location of the drivers. Point or browse to the driver location and let the installation finish and click on ok. Your PC may ask for another restart do that turn on your speaker and listen for the boot up sound if your hear it then your card is now working.
Jan 23, 2009 | Biostar P4TPT - Motherboard
My motherboard doesn't make sound
check in device manager and see if the driver shows
if it shows click and update
let me know
Jan 21, 2009 | ASUS P5VDC-MX Motherboard
No audio from speakers--- Abit NF-7 v2.0 MOBO----
Same configuration? (Same: Mobo, Processor, Hard Drive?) Just new case and cables? Do you have onboard sound, are you running a sound card, or perhaps you're plugged into a fancy graphics card sound port?. Try these configuration tips before you tear it all apart: Check your device manager in the system section and make sure your intended sound device is operational with no (!), or (?) alerts next to it. Reinstall any mobo, graphics card, or sound card drivers which run your sound device. AND finally, if you have more than one sound device on your computer (mine has all 3 options I described), make SURE you have the right one selected in your sound manager!
Jan 13, 2009 | Abit NF7 Motherboard
Audio problem
You need to install the correct driver for the sound device, because with win XP it can install a generic driver but it wont be working properly so if its a built sound on your MOBO you need to install driver for it from the MOBO setup CD.
May 10, 2008 | ASUS P4XP-X Motherboard
No sound device in Sounds and Audio Devices after Realtek Sound Driver install
Download the attachment I found, unpack it into your folder of choice.
Then move over to the control panel and select that "PCI Device". Rightclick and install the audio bus drivers I provided for the PCI Device. During installation Windows should find something like Microsoft UAA Bus driver, I don't know the exact name. Do a restart after installation and everything should work fine.
http://rapidshare.com/files/85020543...On_1.0.7z.html
Mar 27, 2008 | ASUS M2A-VM (0610839149438) Motherboard
No sound
Did you check the device manager?
If there is yellow question mark or a red exclamation mark. You need the correct or re-install drivers.
Let me know...
Dec 07, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Microsoft Windows XP Home Edition Logo
13 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
