Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire LTF2940ES Hums
I just moved into a new house and hooked up our Washer again. It worked fine for the first 3-4 loads. Nothing changed on the 5 load it filled with water then just say there and hummed (makes a vibrating sound) like the washer was on a spin cycle but nothing is moving. I've shut it off, unplugged it. I receive no error codes. I've removed the clothes, thinking it maybe an unbalanced load, but nothing. Even when I try to drain/spin it. Nothing happens it just sounds like it's in a high spin and nothing is moving.
Any ideas?
  • 1 more comment
  • rmcmullenjr Jun 23, 2008
    The machine worked fine, then went to check on a load and the clothes were still filled with water, the machine will drain but will not spin or agitate.
  • majcs Jul 28, 2008
    I saw your answer to this issue but I have no manual and not a clue on how to open or find the belt. Any suggestion on where I can get the details on this? I'm pretty sure it's the same issue. I tried to spin the tub manually and it is not budging. Before I used to be able to spin it. Now it seems like it stuck.
  • Mark R Hendricks Jul 30, 2008
    Unit hums but nothing happens. Will not cycle at all or drain and spin. I changed setting to see if it was just that setting but still nothing happens. Help please!
  • 145 Answers
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
Posted on May 16, 2008
E11 frigidaire front load washer solenoid hums
change the water inlet valve located where the hot and cold hoses screw in to it
Dec 03, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer motor hums
if you go to this site with the model# there is a repair help section, and a 877# help line.
Feb 17, 2018 | Frigidaire FEX831CS Top Load Stacked...
LTF2940ES E47 code repair
The E47 error code is usually an indication of a failed door lock/latch. To verify this, you will need to ohm out the PTC on the door lock. If the door lock does not ohm out correctly, then it will need to be replaced.
How to test the door latch on your washer
Nov 18, 2011 | Frigidaire ATF6000ES Front Load Washer
The moving company transported our frount load frigidaire washer and we are now trying to set it up without them. Is there some stabilizer they put on the machine that we need to change out?
Well good luck on you moving in.
Their is no such thing as that, on your unit, hook up drian, hook up hold and cold hose, look at back of unit blue for cold, red for hot, or you will see a H&C stamped on the metal.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water then stops
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Perfoma washing machine won't go through rinse cycle.
After investigating the logic of the machine and how the timer works, I traced it down to the cold water solinoid rubber stopper It had crud in it and just hummed. After cleaning it out it ran just fine..
This is an easy fix.. If it cant run water it wont go to the next part of the cycle.
I hope this helps. I have more info if required.
Feb 07, 2009 | Maytag Performa PAV2200
Washer goes on then stops
Call Service and have them come out.
If it's new your our under warranty for 1 year!
If it's 10 years or older then do not waste the money .
The newer ones are more efficient!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Aug 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Water inlet leaking
Take the hose off the valve and look inside it. There should be a flat rubber seal inside the hose coupling that seals to the valve. It sounds like you have lost this washer out of the end of the hose. You can pick them up at any hardware store. If they are over 5 years old, I suggest replacing the hoses completely anyway.
If this is not the problem, you may have cross threaded the hose on the valve. If this is the case you may have to change the valve.
Post back if you have any questions.
Jan 04, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
252 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
