Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
After a perfect color print on my CX 5500 scanner printer, the next ones suddenly all have a reddish horizontal line every 7 mm - any suggestions please ?
    President:
  • 4,070 Answers
Hi! You may want to start on running cleaning. This can clear out the lines. Try it and please write back on the progress.
Posted on Sep 15, 2010
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Printer not alligning catridge
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!!!
Sep 15, 2011 | HP Photosmart C5580 All-In-One InkJet...
The printer will print perfectly but will not copy in either black /white or color. Only horizontal lines appear on the page;.I have cleaned the nozzles and checked the alignment.
The next step would be to try to scan an image to the computer to see if you get the same result as a copy. I suspect that the scanner assembly is having an issue, and this would be the easiest way to find out. Please advise if this does not solve your issue.
Sep 30, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Can print the color I want. Only prints red.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Color cartridge do not want to print
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Can't print in color
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
My printer will not print color
Hi.
First check if u r using compatible cartridges for your lexmark printer. You may use the following weblink to find the comaptible cartridges for lexmark printers:
If using correct carts and stil issue, then check the below info to clean the print contacts and cartridges:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier.
Try it out..
Apr 24, 2009 | Lexmark X2500 All-In-One Printer
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
