Question about Husqvarna Designer I
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
    Problem Solver:
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Posted on Sep 15, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
How do i restore designer pape only letter page is showing on screen have husqvarna designer 1 with 4d embroidery extra
I'm not sure I understand the problem exactly. It sounds like you touch pad is not responding properly. Did you notice before this happened that you needed to touch the screen not exactly where the button on the screen comes up. If that is the issue your best bet is to have a husqvarna Viking tech and have the touch screen calibrated.
Feb 11, 2015 | Husqvarna Viking 1
How to open fixed screen? on Designer 1
I would check the Touch Screen first. Your Owner's Manual tells you how to calibrate the touch screen from the SET menu. However if the touch screen isn't working, you can't get to the SET menu. Suggest taking it to an authorized Viking Dealer and they would be able to quickly determine the solution. You can find the nearest dealer by going to the Viking website - http://www.husqvarnaviking.com/us website and click on 'Locate a Dealer'.
Jun 10, 2014 | Husqvarna Designer I
My husqvarna designer 1 keypad doesnt work
It could be the Touch Screen. If it is a Designer 1. If it is a Designer II or Quilt Designer or #1 it could be the Dcard. Recommend it be checked by an Authorized Viking Dealer. You can find the nearest dealer from the Viking website - http://www.husqvarnaviking.com/us Click on the link Locate a Dealer.
May 21, 2014 | Husqvarna Sewing Machines
Husqvarna quilt designer II will not calibrate
Sounds like the touch screen has gone bad. You should take it to your nearest authorized husqvarnaviking dealer. You can find your nearest dealer at http://www.husqvarnaviking.com/us
May 11, 2014 | Husqvarna Sewing Machines
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My Designer 1 touch screen is not responding. I know how to calibrate it, but can't do even that until I can select the options on the screen. Is there a way to unlock it?
I have this information from a person who was a Husqvarna Designer expert:
When you just can't get to the menus at all:
Turn the machine off.
Then hold down the "Reverse" and "Pivot" buttons and power it back on.
You now have the setup screen.
Touch the "Needle Down" button and you will see the crosses.
Use a small blunt object like the metal end of the buttonhole foot (the stylus that
came with the machine would be better ) and
touch the centre of the crosses and each will turn green. Then click on
"save".
Oct 11, 2010 | Husqvarna Designer I
I have a designer 1 and when i select the option block that I want - i actually have to touch below it a whole block for it to register what I wanted!! Help!! We moved states away from where I bought it.
Do you mean that you can't select a stitch except by touching below that stitch instead of on it? If yes, then you need to re-calibrate your screen. It's easy! You should use your stylus for this, but if you have lost it use the blunt end of a machine needle instead.
Go into your SET menu, hit More twice - or until you see "Color Touch Screen Adjust" (it might depend on what version machine software you have loaded just which screen it is on). Click on this. (Keep touching below and around the button until you get it to respond.) Touch in the CENTER of cross 1 (upper left corner of screen). When the cross changes from black to green, the point is set. Do the same with cross 2 (lower right). Done!
Just be sure to touch ONLY THE CROSSES on that screen, except for OK when you are done.
Nov 29, 2009 | Husqvarna Designer I
Designer 1 Problem
Try touching around the button on the screen.  Touch above, below,left & right moving farther away from center. At some point it may clear. If so, use the same method to calibrate your touch screen in the "set" menu.  If not, go back to your repair facility and have them recalibrate in the service mode.
Sep 03, 2009 | Husqvarna Designer I
Touch screen cannot be calibrated
We already fixed the problem, but just the same, our own premium plan is going to cost you ( an eye for an eye)
Thanks
Jun 21, 2009 | Husqvarna Designer I
When I turn on my designer 1 the needle is off center to the right, not centered. Also when selecting a zig zag or other decorative stich it sews something different. Have tried recalabrating the screen no...
These machines are computers are just that: COMPUTERS. Nothing to do but have a mechanic ltake a ook at it for possible fix. It is not communicating with the brain since settings are off. There is a manual on ebay for $5.99 that is a three-part CD and I suggest you go on-line and buy it. It will hep with parts, service and how-tos for your D-1. I have it and find it invaluable for fixing my own machines. Hope this helps.
May 14, 2009 | Husqvarna Designer I
Sewing Machines Logo
837 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
