posted by KGUSA on May 16, 2008
Model - IBM Wheelwriter Series II, Cartridge Printer II
One day I was typing just fine - then the ink stopped working. I thought that if I replaced the "Lift-Off Tape" (1337765) and the "Easystrike Superior Write Correctable Ribbon (1380999)", I would be able to type again. I still can not use my typewriter after replacing both parts - is there something else I should be doing?
Any suggestions would be greatly appreciated! I love my typewriter, even though I use a desktop!
Thank you!
M. S.
Comment by KGUSA, posted on May 22, 2008
Thank you for the solution - I really appreciate this!
Best Solution
posted on May 19, 2008
It sounds like th4e plastic cap on the print solenoid plunger is broken. The part is avail. but a little tricky to replace.
DickyO
DickyO
Rating Locked! (?) KGUSA has rated this solution as Helpful
Solution #2
posted on Jul 19, 2008
Hi Make sure the ribbon is moving while you type. Open the top cover and type. As you are typing feel the turn wheel on the ribbon to see if it is turning as you type. If it is moving and you see the impact solenoid pushing the hammer forward. The cap on the print solenoid needs replacement. If you want mail the t.w. to me and I will replace it for $50.00. If you never worked on this machine you need some one to replace it. iT IS NOT AN EASY JOB. LAWRENCE I have been fixing these for 30 years. Its my business.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Lexmark Wheelwriter 2500 Typewriter
Lexmark Wheelwriter 35 Series II Typewriter
Lexmark Wheelwriter 10 Series II Typewriter
Lexmark Wheelwriter 2000 Typewriter
Olympia Startype 3 Typewriter
Olympia Monica 2 Typewriter
Brother ML-500 Typewriter
Can you Help with these Typewriters problems?
Brother SX-4000 Typewriter
Turn it on and it makes a high...
We just moved. Might have been... Answer This...
Lexmark Wheelwriter 1000 Typewriter
The typewriter is not typing.
I was successfuly typing about... Answer This...
Repair Service
Find Typewriter Repairman Near You:
