Question about Lexmark X5150 All-In-One InkJet Printer
THE POWER CABLE GET VERY HOT AND THE ON/OFF LIGHT BLINKING
  • Official Brand Answer
  • 3,344 Answers
Unplug then replug the power adapter of the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Make sure to plug printer to a power outlet with the correct power specification. Bypass surge devices or power strips. If problem continues, unplug printer from the power source and contact Lexmark technical support to further investigate the problem. Thanks.
Posted on Sep 15, 2010
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Red light blinking
blinking of red light indicates that fault in main board or related boards. you need to open back cover remove each cable connected with main board one by one & put on tv after each cable is disconnected. if red light stops blinking on disconnecting any of the cables, that means related board is defective, if it does not stops blinking, check the power supply is generating proper voltages. if it is ok that means the main board is defective.
Sep 26, 2011 | Panasonic TC-32LX24 32 in. LCD TV
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
My computer is blinking orange light
In addition to the power supply, motherboard issues can cause the blinking power light and no boot problems. The Optiplex 270, 520, 620, 745 and 755 units are all known to have issues with capacitors on the motherboard. Here is a link to an article about this issue and what to do about it:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
I hope this helps, if sol please rate my solution.
BuddyMc
Aug 10, 2010 | Dell OptiPlex 360 Desktop Computer
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
Tv will not light up.
I do not have expertise in cable TV systems. A power failure when you have the TV connected to a system which is normally always on or on standby may need resetting if interrupted. Try the TV on an aerial or with its scart input, but disconnected from the cable unit. The blinking red light indicates a fault
Oct 15, 2006 | Sony KV-32S26 32" TV
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
