Question about Intertherm Heating & Cooling
Outside unit will not turn on. Inside fan works fine. This intertherm unit is an upright, 6yrs old. Model number unkown. Fan will turn. No hum coming from unit. inside condenser sits on furnace model # E2EB-015Hb. Freon charging is outside on the lines coming from outside unit.
    President:
  • 4,070 Answers
Hi! You may want to start on having the power supply checked. Good cause why the unit won't power up. Have the compressor checked too just to be sure.
Posted on Sep 15, 2010
Why is my Intertherm P681S unit getting hot and the fan is is stopping?
Is the outside running? Is the outside fan running? Probably what is happening the fan outside quits running and the compressor gets hot and goes into thermal overload. need to check to make sure the outside fan is running.
Aug 30, 2014 | Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
Intertherm 13 SEER split air conditioner fans wont turn on?
OUTSIDE FAN OR INSIDE FAN OR BOTH. IF BOTH CHECK THERMOSTAT WIRE HOOK UP. IF YOU INSTALLED NEW TSTAT CHECK FOR JUMPER ON RH-RC TERMINALS ON TSTAT BACK PLATE. IF INSIDE FAN COMES ON WITH FAN IN ON SETTING AT FAN ON AUTO LEVER THAN PROBLEM IS AT OUTSIDE UNIT. CHECK FUSES IN BOX ON OUTSIDE WALL. SHUT OFF BREAKER FIRST.
Apr 21, 2010 | Intertherm P3RA-060K Air Conditioner
AC fan not working
turn it off call repairman
Jul 11, 2009 | Heating & Cooling
Air conditioning not working
Turn fan to on position to see if it comes on. If you amy have a bad fan relay ot fan capacitor. Need to call service tech sorry
Jun 15, 2009 | Heating & Cooling
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Fan will not turn
Several possibilities, but most likely a starting capacitor failed. Could also be a bad compressor. Go ahead and call a repairman.
Jul 12, 2008 | Intertherm Heating & Cooling
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating problems
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Jan 15, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
