Question about Nokia 5800 XpressMusic Smartphone
Firstly,the little gold pin that is the charging point on the fone where the charger is connected,broke off so i am unable to charge my fone so i have been temporarely taking my charger out my fone and putting into my daughters cellfone (which is a different nokia make)and charging my battery,then putting it back into my fone which is a nokia 5800 music express.The problem is now is that it switches off every now and then and it is not because the battery is low,i then have to switch it back on,could i have perhaps damaged the battery?
    President:
  • 1,216 Answers
No,
if your daughter's phone has a Bl-5j battery.
and yes if not.
Another thing switching off of the phone is a virus issue and please format your memory card for this
Posted on Oct 12, 2010
Will not charge/stay charged
you charger wire connection is loss so you have to use wiretap properly or you have to buy a new charger
Jun 09, 2017 | HTC Rezound
Not charge batery bi its own charger
1.Check you charger firstly.
2.Use another charger
3.If it get charging by another then change your charger.
4.If still problem occur then you charging point on you handset will be damaged
5.Repair you charging point
Aug 04, 2011 | Nokia X3 Cell Phone
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
Battery not Charging
hi :) about battery mayb just a little pro only. u can try to check yr battery charging detect point.i mean the gold colour :) or the charger oso have the gold colour detect point.(it same position detect with yr battery point oso) well,check the both item Point wt i write as above.if it look some dirty ?? juz take some tissue paper clean it up :) Ps: after clean still not work,pls check the charger wyre. good luck :)
Jul 04, 2010 | Vtech Cordless 6041 Phone
Won't Charge- Is there anything I can do?
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Jun 14, 2008 | LG enV VX9900 Cellular Phone
Charging prob...
may be the charger is not correct... if it is correct also the pin hole which connect the cell may have became big.... or ur cell charging pin is damaged.... just try with the another charger... u will get rid of it...
if it doesnt works means surely the charging pin in cell is damaged... get replaced with the technician....
Jan 29, 2008 | Motorola Mobility V235 Cellular Phone
T-mobile phone Not Charging
to where are you connecting the charger?
how old is the charger? maybe the cable its broken in the inside... this usually happens at the ends of the cables or if there is a little bump somewhere..
try connecting them and play with them by moving them a little at the ends.... so there will be better a contact..
Dec 11, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Nokia 5800 XpressMusic Smartphone Logo
127 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
