Question about Westinghouse Televison & Video
I purchased my 42" plasma westinghouse TV in Taipei and brought it to Manila. I have been using it for 31/2 years now. Two weeks ago while we were watching with it the color and sound were suddenly disapeared. I tried to turned it off and reopen again but it does'nt work anymore. Do you think this can still be repaired? Do you know any service center available in Manila where I can bring this check up and repair. Best regards, Fred Gaffud
  • 34 Answers
SOURCE: LG plasma TV
I would suggest having the Y and Z Sustain boards replaced
Posted on May 22, 2008
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: No Picture on Vizio 42 in. Plasma
the logic control board defected, replace it & picture will come back.
Posted on Sep 11, 2009
  • 4 Answers
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
MY TV is LG 42 PG 60D , serial number :803KCBD35285
Sound like ur Tuner board have intermitint problems,it work awhile,than the old problems occur again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Because this problems come and goes.
Apr 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red dots on a black background
Try to adjust the Vs down about 5-10V.
Jan 05, 2008 | LG 42PC1DA 42 in. Plasma HDTV
No power
i used my plasma 42'' model MT-42PM11 about 3yrs ago i found out after a week that there is black middle bar on the screen how to solve this issue.
Dec 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
Philips Plasma 42" - constant purple haze
if the set is less then a year old it may be under factory warranty.
it sounds like the vscan, vset , or vsus voltages are off..it could also be the panel itself..contact philips
Nov 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
