Question about StarTech.com StarView SV211K 2-port KVM Switch
Havent got all the channels. - StarTech.com StarView SV211K 2-port KVM Switch
    President:
  • 2,571 Answers
You wont
Virgin has now switched to nagravision 3 encryption.
All eurovox/starview boxes can now only receive SOME free to air programs.
If you rescan, all the programs are picked up, but all the encrypted channels are blocked.
There is no fix yet, and there will probably be NO fix for your box, or any box without an ethernet connection.
Check afterdawn.com or techkings for more info
Posted on Sep 18, 2010
Sound is only coming out of the left headphone when I play
Is this the same on all channels?
Check your 3.5 -> 1/4 adapter is stereo (2 black bands on the connector) and check you havent got it set to mono.
Try with different headphones too.
Hope that helps!
Jul 05, 2011 | Live Wire Solutions HA04 4 Channel...
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
Am loseing channels every time i scan the tv some channels come correctly others apparently havent signal orignally all local channells came in perfectly now a couple channells come in perfectly when...
Depending on the signal strength of those channels on the days you do the scan your tv may decide that it is not a good enough signal for it to even bother programming into your normal channel list.
The weather will honestly have a lot to do with pulling in over-the-air broadcasts.
Nov 04, 2009 | Vizio L32 32 in. LCD HDTV
Ex 5100 pvr scrambled channel problem
you need the scramble code and/or filter for whatever specific channel you are trying to recieve. there is no legal way to get this except from the subscription line for whatever channel it is you want.
Aug 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Chorus cork codes super usb box
the codes havent been changed its just how chorus are sendin out the channels
May 31, 2009 | StarTech.com StarView SV211K 2-port KVM...
How come I can play video tapes on my sony video casette recorder, but can not record tv channels on my recorder?
i guess you havent connected it correctly.
Run your ariel int antenna (RF) in on the video recorder.
You will need another (RF) cable that connects from RF-out on the video recorder to antenna in on the tv.
put the tv onto channel AV (or video)
tune (scan) the TV channels on your video recorder.
NOW you will be able to record the channel you see it play on TV
hope this helps!
Apr 06, 2009 | Televison & Video
Bearcat scanner bc248clt
I Need to no how to prograamed channel and scan
Sep 18, 2008 | Uniden BC248CLT Base Scanner
STARVIEW BOX
have you turned of your emu, that may help but cant under stand why you havent got any channels at all, give it a check though gl
Aug 08, 2008 | StarTech.com StarView SV211K 2-port KVM...
Changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Apr 20, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
62 people viewed this question
Top StarTech.com Computers & Internet Experts
loftys0504
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
