Question about 3Com SuperStack 3 3824 (3C17400) 24x1000 Mbps Networking Switch
How can i reset password of 3Com SuperStack 3 Switch 3824 24-port
4 Suggested Answers
sandeep239
  • 59 Answers
SOURCE: Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Posted on Mar 05, 2009
marked
  • 6487 Answers
SOURCE: My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Posted on Jan 27, 2010
  • 17 Answers
SOURCE: I want to know the
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Posted on Jul 18, 2011
3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Apr 12, 2012 | 3Com SuperStack Computers & Internet
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Jul 18, 2011 | 3Com 4500 24-Port Ethernet Switch
My problem is i have all yellow ports flashing in 10 3com 3300 switches in the same time. please help me
  1. Using a Null-Modem Cable , hook up the Console port of the switch to an available COM port on a computer (cable must be able to provide serial port communication between 2 computers).
  2. Set up a Hyperterminal session to that COM port (e.g.: com1), with the port settings at 9600/8/N/1/N (. When the screen comes up blank with a blinking cursor, hit [enter] once or twice to bring up a login prompt.
  3. Alternative to 1 and 2 above, if there is a known assigned TCP/IP address for the switch, one can telnet to that address, hit [enter] once or twice to get the login prompt.
  4. Default logins to try are admin/(no password) or security/security. One of those 2 should bring up the management menu.
  5. To reset factory defaults, type SYSTEM[enter] then type INITIALIZE[enter]. This will reset everything that has been set up on the switch, with the exception of the TCP/IP address, if there is one. All other previous configurations will need to be re-entered.
  6. You can type in username "3comcso" and password "RIP000". It will ask you to reinitialize the switch. This will reset all settings including passwords.
Jul 15, 2011 | 3Com SuperStack 3 3300 XM 24-Port Ethernet...
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
How to recover old password on 4300 switch?
you manually RESET your device by pressing the "reset" button at the back. it will be reset to factory setting with the default password loaded.
Regards!
Jul 13, 2009 | 3Com 3C17100 /RETAIL3COM SUPERSTACK III...
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Doesn't POST
I've got a Superstack II 3300 24port switch, all leds are on, and led 8 blinks.
I'll let you know if I find a solution.
Dec 09, 2008 | 3Com SuperStack 3 3300 TM Networking...
3COM network switch access problem
You Could check to see if it has a passowrd and username as 3com or user as username or password thats wat mine is and i forget my pass
Aug 04, 2008 | 3Com SuperStack 3 4924 Networking Switch
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Nov 20, 2006 | 3Com SuperStack 3 3300 TM Networking...
3Com SuperStack 3 3824 (3C17400) 24x1000 Mbps Networking Switch Logo
756 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
