Question about Sony STR-DA50ES Receiver
I have a Sony STR-DA50ES, I have visual but no sound on all channels. could you help?
4 Suggested Answers
  • 6 Answers
SOURCE: Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Posted on Sep 01, 2007
SOURCE: protector fan
i have the same problem , help me umbertknot@hotmail.it
Posted on Jun 28, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Protector flashes everytime the unit is turned on.
Please see the link below for a generic explanation about protect mode. Please post any additional questions that you may have here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Sep 10, 2010 | Sony STR-DA50ES Receiver
I need a motherboard for a sony STR-DA50ES audio receiver and no shop was able to find one.
These boards are no longer available from Sony. What is the problem you are trying to solve? I have never needed to replace the entire board. One other option is to locate a "broken" unit from shop or Ebay and use the board from there.
If you can describe the problems, perhaps we can help to repair the existing board.
Dan
Apr 21, 2010 | Sony STR-DA50ES Receiver
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Mar 24, 2010 | Sony STR-DA1000ES Receiver
Sony DA50ES makes loud and scary clicking noise after its been on for about ten minutes, its loud enough to be distracting and annoying while watching movies. I'm wondering if I need to buy a new receiver...
Is the noise audible through the speakers or is it a physical clicking directly from inside the receiver?
If the former, what source(s) do it and are they digital or analog?
It doesn't appear there is a fan so NO physical noises should emanate from the receiver. I'd suspect an arcing component or something electrical. THAT might be dangerous to the receiver or even a fire hazard. Get it looked at.
Feb 24, 2010 | Sony STR-DA50ES Receiver
Sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Nov 24, 2009 | Sony STR-DA50ES Receiver
Makes an loud clicking/popping sound
The audio outputs are intermittently shorting to their supply and allowing DC voltage to pass - the speakers will be damaged if it continues. you can confirm this by measuring (with a dc voltmeter)at the speaker outputs for DC volts.
Sep 19, 2009 | Sony STR-DA50ES Receiver
The system will not power on. I changed the blown fuses but when
Sony has service centers in several areas of maryland. If you go to www.sonystyle.com and "Support" you can find one in your area. Hope this helps. If you can't locate one, I use to Live in MD. What area? post a comment and I can find a good svc center for you.
Aug 16, 2009 | Audio Players & Recorders
Analog input problem
same EXACT problem it is a PIECE of **** !!
Schafe1001@aol.com
Mar 06, 2008 | Sony STR-DE445 Receiver
Protector fan
Sounds fried. Time for a trip to the shop. Good luck.
Jan 22, 2007 | Sony STR-DA50ES Receiver
280 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
