Question about Humax Televison & Video
I own a Foxsat-HDR recorder and the screen aspect ratio is now larger then can be contained on the screen of my Panasonic TX-L37G 15B, so that the picture is cut off at the sides and the bottom of the screen. On booting up the recorder, I receive the following: DVD DVD 16:9 Wide 1080I Wide DVD 16:9 DVD DVD 1080I Wide DVD ZOOM 2 DVD 157I Input wide Can you tell me how I can get the aspect ratio to fit the size of my TV screen please?
C-Dog
  • 84 Answers
SOURCE: aspect ratio
Try changing the screen settings for your cable provider's cable box menu. Alot of times they're not properly set in the customer's homes.
C-Dog
Posted on Feb 10, 2008
  • 1039 Answers
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Posted on Apr 25, 2009
  • 418 Answers
SOURCE: How do I change the aspect ratio?
Look in the settings in the u-verse setup if it's HD box.
Posted on Apr 19, 2010
SOURCE: I am Playing a dvd of West Wing tv show from a
I don't know, but I'm having the same problem.
emailbillphillips@gmail.com
Posted on Jul 16, 2010
toolkits
  • 1099 Answers
SOURCE: On turning on my humax
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
Posted on Nov 02, 2010
How do i stop my humax foxsat-hdr recording a series when i only want one?
press to record again the same programme it will give you an option to cancel
Nov 07, 2015 | Humax Televison & Video
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
Apr 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Can i download a manual/user guide for my foxsat-hdr recorder?
Yes. Try this manual;
www.humaxfoxsathdr.co.uk/.../Humax-Foxsat-HDR-User-Manual.pdf
Feb 21, 2011 | Humax Televison & Video
Panasonic TV model no TX-32PD30. Resolution has changed ie become larger and we are losing full screen picture - people are cut out of the screen.
The most likely cause of this is that you have accidentally changed the screen aspect ratio. There should be a button on the Panasonic remote marked "ASPECT". With the TV switched on, try pressing the "ASPECT" button repeatedly until the picture either returns to the correct size or you are unsuccessful and cycle back to the original picture size.
You will probably find that you are currently on one of the "ZOOM" settings. The correct setting should either be "AUTO" or "16:9".
If this does not solve your problem, please post back for further assistance. If you are using another receiving device, e.g. a Sky / FreeSat or Freeview box, it is also possible that you need to change the ratio setting of the receiving equipment. Please let me know the details of any additional receiving equipment you are using if/when replying.
Regards,
BElectric.
Dec 30, 2010 | Panasonic Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Aspect ratio makes no difference
Can you go into menu and turn off autoformat?
Oct 08, 2007 | Panasonic TX-32PK1 TV
Televison & Video Logo
47 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
