Question about Curiosity Kits Toys
I need the instruction sheet for Curiosity Kits Kooky Krayon Machine. We lost ours and since it involves melting wax I want to make sure they are using it properly. Please email the instructions to Bergkv2000@yahoo.com
t0pc4t
  • 132 Answers
SOURCE: Instruction Manual Paper
Can I make a suggestion - -
Have a look on Ebay for somebody selling this item.
You will likely find an email address . .
Most people would probably be prepared to scan a copy in and email it over to you at no cost.
I know I would be happy too.
Posted on Aug 16, 2008
SOURCE: Need Manual/Instructions
after much searching, i found the instruction manual for this unit in pdf format, @ http://dl.owneriq.net/e/e2989a56-98b6-67c4-69f8-21ce50aeb9b1.pdf
Posted on Aug 27, 2008
SOURCE: Carrozzeria AVIC-XM520 English Operating Instructions
if any of u guys want s to sell the unit let me know mistersti206@yahoo.com
Posted on Oct 10, 2008
bunnydawg
  • 5158 Answers
SOURCE: Lost instructions!
you can get it here... it's 2am so i'm too tired to search further then that.
http://www.wildplanet.com/helpcenter/instructions/
Robert
Posted on Dec 18, 2008
  • 7 Answers
SOURCE: Shrimp Instructions?
Hi brine shrimp are sea monkeys just google see monkey hatching instructions they will be the same. my instructions do not have the information either but my set came with the brine shrimp. you just wont have pouch #1
http://www.discoverthis.com/sea-monkey-instructions.html
http://www.discoverthis.com/seamonkeys-hatching-temperature.html
Good luck we had 4 generations of sea monkeys. When they fie off you can let the water evaporate from your tank and Add new water and the cycle wiil start all over. we are in that process now 4th time...
Posted on Jan 10, 2009
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
How do i remove melted Nair hair removal wax from bed sheets
Ice...Use Ice. Freeze The Wax And Try Cracking It Off Then.
Mar 05, 2012 | Refrigerators
How do I remove crayon wax that melted in the sun onto my wrought iron deck table
There are a few methods. You can take ice cubes and place them on the crayon wax until it freezes. It can then be easily removed. You can also place a paper towel on the wax and use an Iron to heat the wax until it melts. The paper towel will absorb the wax. Then use a dryer sheet to remove anything left over.
Jul 10, 2011 | Garden
11026892690 will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Every motorized treadmill must need some regular type of servicing. What is the procedure? What do I need to do to keep my treadmill in good working order?
The main thing to do is keep the walk belt area clean of all shoe rubber and lint,vacuum the tread melt and edges regularly.Most treadmills have a wax lubricant in the walk belt,youcan purchase this lubricant at store that sell treadmills or you can do an on line search for treadmill lubricant.If you lift the belt and feel under the platform you should feel a slight waxy film, if not you should add wax as needed,some wax kits come with instructions, but if you just apply it to the platform area underneath the walk belt where you feet normally land when to step forward that should be fine,walk on the treadmill for a few minutes to spread the wax evenly on the underside of the belt, other than that there is no other maintenance needed.
Jul 10, 2009 | Exercise & Fitness
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Maytag Washer model# mah3000aww
out of curiosity why did you replace the wax motor?? did you also replace the machine control board behind the console??? usually thats the issue with this machine is one or the other goes bad and recommend fix is to replace both.A quick visiuall check will determine if htis needs replacing as well, theres athermisotr the blows out). you say you get power to the wax motor, so it should then energize pushing forward into the next to switches, firs one locks door and put on indicator light, the second is actually the spin switch that needs to be activated for the machine to enter a high speed spin
Mar 26, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag door wont lock and go into spin cycle
You will need to replace the door interlocking device.
Oct 26, 2007 | Maytag MAH6500 Neptune Front Loading...
Toys Logo
47 people viewed this question
Top Curiosity Kits Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Curiosity Kits Toy Expert? Answer questions, earn points and help others
