FixYa.com
Tags:
Emerson MW8102SS 1100 Watts Microwave Oven
Need to replace the entire door
posted by tonybram on May 16, 2008
The kids accidentally punched a hole through the door of our microwave.  I was able to find a replacement door.  Hoever before purchasing it, I needed to know how the door comes off the frame. I've looked at ours several times and am stumped.  I can usually fix just about anything, but this one has me!  Can you help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2378 votes
Normally you have to remove the outer cover of the microwave.
I strongly recommend that you mark the position of the hinges before you remove them.
If they are not in the exact position after the repair, microwave leakage is likely.
You may be able to just remove one hinge. That's usually the top one.
If this is not enough help, then Please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Microwave Ovens problems?
Light Not working
Light does not come on when the... Answer This...
emerson mw
where is the thermal fuse... Answer This...
probmlem with emersom mw
I have an emerson Microwave... Answer This...
help
i have 2 red light boxes... Answer This...
Front panel of the door just...
Is there any way to safely... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
