Question about Toshiba 32A14 TV
I turn the tv on, and there is no picture, but there is power, the red light comes on. take the back of the tv off (the shell) plug it in, and it works, as soon as we go to put the back on- it comes within an inch of the tv... it powers off again. tv works great with the back off, but does not work with the back on (???) anyone? very confusing...
techman
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
SOURCE: Flashing Red Power Light
i had to replace the power supply
Posted on Oct 26, 2007
  • 244 Answers
SOURCE: power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Posted on Nov 24, 2007
andyroid85
  • 7 Answers
SOURCE: Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Posted on Aug 28, 2008
ginko
  • 19396 Answers
SOURCE: blinking power light TV doesn't turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Panasonic TC-54PS14 54" HDTV Plasma TV
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Toshiba 32A14 TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
