SOURCE: Will not turn on MP830
I just had the same thing happen to me. There was a lightning storm here on Saturday night so, even though I have a surge protector, I assume that it took a surge. HERE IS THE SOLUTION! If you unplug the printer (pull the plug!) for at least 20 minutes (which lets the system discharge)then plug it back in, the system is allowed to reset and will fire back up when you press the power button. I know the above post is 3 weeks old, but I'm hoping this will help other searchers like me as well.
SOURCE: Emachine T2958 will not turn on - has no power
Dear asksforhelp,
As u have told that u have change the power cord then the second thing u can try that check the SMPS is it working or not to check this u have to know that where is the SMPS where u pluged in the power cord in the cpu that thing is SMPS check wether the SMPS fan moving or not if no then u have to replace the SMPS if it is working then u have check wether the mother Board get the power supply or not check the 12 pin power connector insert it in mother Board if still it not working then it is definatly problem with u r Mother Board. So it is better for u that to go for New One.
SOURCE: HP Pavilion Entertainment dv6000 will not power on
Did you try taking out the battery for a while?
SOURCE: HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
