Panasonic WJ-AVE7 digital mixer; Unit will power up but no functions available. Bought used on ebay, worked fine for a couple weeks.
  • sozz7
    sozz7 Apr 24, 2009
    I just bought a AVE7 which is apparently in excellent condition, according to the ebay listing, but doesn't do anything except light up the red power light, any suggestions?
Did you solve this yet? I may have a solution
Posted on Mar 07, 2009
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
Cannot get TV/VHS unit to work.
sounds like the vcr lock feature is on,
hold down the rec/time button for 7 secounds during the power on mode.
ushally goes off within 24hrs if the time is set. but seems maybe thats a issue.
try that see what happens.
and if possible give the model number of the unit please.
Quasar is made by panasonic and their guides and manuals can be found there as well..
I found this manual hoping it was close to yours take a look and let me know.
http://service.us.panasonic.com/OPERMANPDF/VV1308.PDF
Aug 11, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
I brought an MX-AC300 PANASONIC mixer grinder from india to usa.its not working.it's not start even once.can any one help me out on this .i used voltage coverter also.
did u check it( i mean whether it was working) in india if not look in to the warranty period and find out what u can do.. i have bought the same mixer and i'm going to take it to finland in a couple of months.. at present in india its working fine.. and one more qn is it the first time that it's not working.. or it stopped working.. coz too much of rotating might even harmed the mixer.. remember for this mixer it should not go more than 3 min..
Mar 29, 2010 | Food Mixers
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Mixer/Blender not working - works only when tapped
It looks like there may be some loose wire connection. Or it may be due to carbon brush probelm. We at Inno Concepts or any of our dealers can diagnose and fix the problem for a reasonable cost. Please contact us at 770-594-1815 or send us an email with all the details to info@innoconcepts.com
For grinding hard vegetables, use thinner pieces not more than 1/2" in any dimension.
Jun 23, 2009 | Food Mixers
Panasonic DMC-TZ3 Stuck Lense & No Power
You may be able to free up what is hanging lens by rapping the camera smartly against the heel of your hand, or on a harder surface covered you a cushion of two laps of bath towel. Do not rap the lens itself of course.
If this does not work, you can try puffing a small amount of graphite lube into the two shelled sections of an extended lens and get it to retract and extend a few time. If this works, wipe the extended lens down good with a dust attracting cloth. Graphite lub is used because it does not attract dust, making a friction problem even worse over time, like oil based lub do. Graphite lub is available at any HW store in a small plastic tube made to squeeze, expelling (puffing) a small amount of fine graphite onto a precise locations.
If none of this works, sell your camera to a repairman on an ebay auction, and replace it with a working used, refurb w/warranty, or new one from ebay. Prices are cheap because the TZ3 has been replaced with the newer TZ5, and millions of TZ3s, an awesome camera I own, were sold. .
Sep 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMR-E85H Not Starting up from standby
Try unplugging the unit for 24 hours. If that does not work, then most likly there is a problem in the microprocessor circuit or the main power supply circuit. There are no user replaceable parts inside this unit, so if yop wish to invest into this unit, your going to have to take into a servicer to get an estimate. I will warn you, most likly it will not be worth the estimate fee, as these things these days are throw away electronics. Its just a shame, things are not made like they used to be. Well Good Luck. Please do not forget to rate this thread.
Dec 07, 2006 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
651 people viewed this question
Top Televison & Video Experts
