Question about Ricoh Aficio 1035 Copier
When i switch on my copier it says. FUNCTIONAL PROBLEM DETECTED. TURN MAIN POWER SWITCH OFF THEN ON. IF THE PROBLEM APPEARS AGAIN PLEASE CALL SERVICE
Functional problem
change the td sensor below the developer unit or if possibly change the complete developer unit
Jan 02, 2014 | Ricoh Aficio 1035 Copier
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
FUNCTIONAL PROBLEM, SC544
A fusing temperature of over 250 °C is detected 5 times by the main control
board (this takes 5 seconds)
- Possible Causes -
· AC drive board defective (check the triac)
· Fusing thermistor defective
· Main control board defective
For safety reasons, Level A service calls cannot be cleared by
turning the main switch off/on. The following procedure must be
performed to clear these service call conditions after servicing
the machine.
1. Turn on the main switch.
2. Enter SP5-810 (SC code reset) and press the Enter key.
3. Exit SP mode and turn the main switch off and on.
Jun 10, 2011 | Ricoh FT5832 Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
Describe your ricoh aficio 350 functional problens Problem sc 547-00
The applied power supply ac frequency
was detected at over 66Hz or below
45Hz, and the zero cross signals are
not detected within a certain period
within 500 ms after the main power
switch has been turned on. Pls check power supply board or try to use an AVR (autonatic voltage regulator)
Jan 22, 2010 | Ricoh Aficio 450 Copier
C-2551
C2551: Abnormally low toner density detected Cyan TCR Sensor
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jul 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Functional Problems SC350 - 01 Turn On/Off Switch off the On If the error appears agian Call: Service; 00 - 0000 - 0000
I have recently provided a post to the same problem. Please note that the Power must be turned off with the "main power" (red button) to reset.
The link is here:
http://www.fixya.com/support/t1999925-sc350_01_error_code
Please let me know if this helps, and rate my solution :)
Apr 23, 2009 | Ricoh Aficio 450 Copier
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1035 Copier Logo
915 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
