Question about Symbol LS3408 Barcode Scanner
RS232 Scanner scans bar code but no data on pc???
5 Suggested Answers
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 74 Answers
SOURCE: Hello!
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Posted on Jul 13, 2009
  • 51 Answers
SOURCE: Magellan SL Scanner/Scale PC Connection
first go to posspecialist.com ok get a usb sr232 converter than it will work but not in vista with xp ok
Posted on Sep 01, 2009
SOURCE: I have a brand new MC3090G-LM48H00LER wireless bar
find WLANs showing adapter unavailable
Posted on Sep 18, 2010
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
I wish to connect a bar code scanner to my Keyboard Display Unit for inputting data when printing labels. Can you provide information relating to pin outs, protocols and how to set this up? Thanks
By Keyboard / Display unit I'm assuming your using a PC, thin client or dumb terminal. If you are using a PC then the easiest way to do this is to get a bar-code scanner with a USB interface, no programming should be required with possibly the exception being of adding a "Enter" (CR LR) after each scan.
If you have a dumb terminal then you may need to look at trying to use an RS232 connection (if one exists) or a keyboard wedge solution where the scanner is plugged into the keyboard port along with the keyboard.
In any event pin outs would vary depending upon the scanner you want to use and the device you are connecting the scanner to.
Hope this helps
mikeo@acebarcode.com
Mar 02, 2011 | Zebra Eltron LP 2824 Thermal Printer
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Need my p470 symbol scanner to auto enter
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code
(Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any
Criteria 2 Code Length = Any Length
Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code
(serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
Dec 25, 2008 | Computers & Internet
Symbol LS3408 Barcode Scanner Logo
50 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
