Question about Dynamic MX91 Handheld Blender
Where can I purchase a replacement blade for our kitchens dynamic blender
  • 40 Answers
Https://www.novon.com/novon_store.php?crn=124&start=3 I know it's a bit late but visit this site if you still need one.
Posted on May 17, 2011
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
We own a kitchen aide blender and it has started to leak. This jar does not come apart. do we need to replace the jar?
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Mar 13, 2011 | KitchenAid KSB560 5 Speed Blender
Dismantle Dynamic MD25 blender
Spares from http://www.nisbets.co.uk/
Take out handle screws, pull apart carefully. Take out pins mounting motor to shaft and pull out motor. Take screw from blade and pull off. Pull out shaft.
Jun 01, 2010 | Dynamic MD95 Handheld Blender
Cutter blade
UK supplier is Nesbitts
Feb 03, 2010 | Dynamic MD95 Handheld Blender
The nut that holds the blade is loose and liquid gets through it. When I tried to just tighten the nut is spins but does not tighten. Is there a trick
It sounds like the blade has overheated at some point. When this happens the plastic melts and the seal is broken. The only repair is to replace the blade unit:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Jan 07, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The rubber gear that turns the blade in the kitchen aid blender is stripped how do i get a new one or a new blender?
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Jun 25, 2009 | KitchenAid KSB560WH 5-Speed Blender
Dynamic mx91. noisy.
dynamic mx91, motor runs but blade doesn't spin, how do i disassemble the blade & shaft?
Feb 08, 2009 | Dynamic MX91 Handheld Blender
Dynamic MX91 Handheld Blender Logo
103 people viewed this question
Top Dynamic Blenders Experts
eyecam
Ross Keen
Are you a Dynamic Blender Expert? Answer questions, earn points and help others
