Question about Freezers
My chest freezer has a build up of ice on the left hand side of the lid
  • 4,793 Answers
THEN YOU HAVE AN AIR LEAK AT THAT SIDE OF THE LID....
use blocks under the unit to get it square with a spirit level.......
Posted on Sep 15, 2010
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Ice in freezer door of chest freezer
you should done the work according to freeze catalogue.
Mar 05, 2013 | Freezers
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Chest freezer ice is filling up around the top of the inner lid
Turn it off, remove the stock, tap the sides with a block of wood and scrape to the bottom of the freezer with a dustpan and scoop it out. Refit the stock and switch back on. Takes 10 minutes. Check the lid seals properly once defrosted and check it's not accidentally in superfreeze mode.
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
There is freezer burn on chicken in plastic packages
Hello
Welcome to Fixya
My name is Huum,
You need to use good freezer bags and not just plastic bags in the freezer.
And use these products witin six months..
When you put food into a plastic container for the freezer.
you need to burp the container.
That means to hold it with two hands and with one hand raise the corner of the lit a tiny bit while with the other hand you press down on the center of the lid and close the corner quickly so as to have burped out most of the air in the container. a little like a vacuum packed container.
So less air is in the container to cause condensation inside which is the frost you are getting
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Frigidaire Freezer Refrigeration White...
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Freezers Logo
99 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
